Wheel offset
This should be close.
LineaCorse Lemans - Hyper Black (5x114.3/+15+20)
Rear Fenders cut with a 1/4" lip still. Fronts cut smooth w/o lip
19x8.5 - 225/35/19 up front
19x10 - 245/35/19 out back
dropped on Tom's coilovers
Fronts are 2 degrees of camber
Rears are 3.1 degrees of camber
![](http://img694.imageshack.us/img694/3256/photoge.jpg)
![](http://img22.imageshack.us/img22/1450/photo2sa.jpg)
![](http://img34.imageshack.us/img34/9350/photo3hn.jpg)
![](http://img693.imageshack.us/img693/5640/photo4ig.jpg)
![](http://img18.imageshack.us/img18/2487/photo5km.jpg)
Things to note:
- With enough camber the rear lips will tuck
- If you do not shave the passenger fender smooth, you will pull it out turning into driveways, shopping centers, etc. The best advice I can give you is to shave that fender first if you're gonna be low.
Thank you drive though.
Things to note:
Things to note:
Things to note:
damn man very nice set up now how is the camber does it eat up a lot of tires or is it okay
Riddle me this:
Dropped on BCR coilovers. Want to slightly tuck tire.
19x8.5 / 19x10 -step lip
245/40/19 & 275/30/19
What offset for no shaving of fenders?
I'm rolling them but don't want to shave them. Thanks.
![](https://hphotos-snc3.fbcdn.net/hs397.snc3/24144_410863178139_655073139_5092950_3871477_n.jpg)
Phew, that's a tough one. Even with something like +35 out back those are some wide tires. I would say 35 or 40 something but reduce that tire width. Personal choice really but I run 225/35/19 up front (with a moderately low offset) and look at the pic above......
I've decided to run stretched tires. 225/35/19 F & 245/35/19 R......then I'll be slightly conservative on the offset, +33 F / +28 R then wheel spacer to desirable stance. It's my semi-daily driver, so this will have to do.....for now.
stretch tires.... and offset is everything and that's how u rock it.. i was influence by www.hellaflush.com - www.stanceworks.com
Things to note:
Things to note:
DETUNED
Wheels, Tires & Brakes Forum
05-09-06 09:33 PM
