DIY AC Compressor and Condenser/Drier replacement
#31
So to clean the expansion valve without removing the dash, I would need to flush the system from the firewall and flush the air/debris out the other end of the firewall? Any help is appreciated.
I'm replacing the condenser/drier, the compressor and flushing the lines with ac flush/air.
#32
If your A/C system has been completely evacuated, and by that I mean, I busted the connection with a pole about 10 feet away, (was doing timing belt, oil pump and so on) and I never refilled my A/C with anything, including the oil that sprayed out as well. Could this cause a whining noise at start up, but goes away completely once warm? I can't figure out what the noise is, sounds like it's either my A/C, or my water pump, which I also replaced. Can't seem to pin point it but it goes away when the drive belts removed.
#33
When you guys are flushing the lines, you are removing the AC line from the firewall too right?
There was some talk here about flushing the system should clean the expansion valve, how is this done?
#34
Great write up! Gives me some confidence to do this DIY on my '98 GS400 with 217k miles.
My compressor began clicking loudly (periodically). Especially at engine start. I topped off the freon with a canister that came with guage. Stopped 90% of the clicking and driver/passenger were same cold temp once again. HAPPY!
After about 2 weeks, ac temp was blowing warmer, clicking returned often. After 2 days, clicking was almost constant. Also notice extreme engine lag at takeoff from a stop with AC on. With AC off, engine performed good.
Refilled with freon canister again. Worked for a few hours, then GONE. No AC, blowing hot, outside temp (105 today :-( )
So, I'm thinking compressor, condenser and dryer replacement. All 3 Denso parts on Amazon are about $410.00.
Think I am diagnosing this right?
#36
Is the clutch engaging? Seized? That's what needs to be identified first.
#37
I did this DIY. I replaced the condensor, compressor, O rings, flushed the lines,vaccuum pumped for 1.5 hours (removed all the moisture, and checked for leaks), rented all the tools from autozone (pump, gauges, flush kit can), put it all back together and the car is blowing ice *****. Car runs a lot quieter with the new ac pulley.
#38
I'll research and check out the AC relay switch.
Thoughts?
#39
Just to add...
The 300 gets a new (Rockauto) Denso compressor Saturday.
Old compressor with 210k miles has internal failure, high side stayed at static pressure 80psi or so and low side was fluttering at 80+ psi. No audible noise.
#40
#41
Correct...
Refrigerant should always be measured and added by wieght.
I use a digital kitchen scale and subtract the wieght of the valve and can. Not super accurate but within the broad factory tolerances.
I refilled the GS with just shy of 23 ounces, I would have added more if needed but I was getting 35* at the center vent with ambient temperature at 98* and 65% humidity.
#44
You should purge the yellow supply hose from can to manifold every time you connect a can.
It doesn't take much and I didn't waste but a fraction of an ounce each time.
Our GS's take 19.4-22.9 ounces of 134a refrigerant.
