full tank of gas=240 city miles!!!
I fill up usually between 1/8 and right when light comes on. So 320 miles driven divided by 15 gallons used is 21.333 miles per gallon. Right? This is a rough estimate sometimes its more than 320 or less than that I don't keep up on my TP all the time and so many different variables
i just recently did that as well, this time i actually reset my ecu so maybe that might help after it reconfigures itself? the K&N is not drenched in oil, alot of folks i know tend to over spray the oil and thats what slobbers over the maf i put light coats where its medium-pink and not bright red.
maybe its the spark plugs. I changed out my oem denso's for the NGK IFR6711's :\
however, i did get abt 400miles once during a road trip.
Ethanol does take more to burn, so gas mileage would be affected. Using gas without Ethanol would give you better gas mileage. But you got no choice if you live in an area that uses Ethanol.
The MPG shouldn't be that much either, I'm assuming 1-3 mpg difference.
i just filled up at about 16.43 gallons cost me about $49.00
i got 240 miles to the tank before then. so ill see what i get this tank. but def going to figure out what this misfire is cause its killing my gas!! or are the 8cylinders that bad at gas mileage
cause with the gallons i put in the car and how many miles i got this past tank im getting
240/16=15 miles a gallon!!!!
and i drive a gs400
and i drive a gs400
I would be satisfied for that gas mileage LOL living here in Brooklyn, gas mileage for my GS400 is about 10-12 miles per gallon. And NO its not only my car, from full, doing nothing but city driving I get about 200-220 miles outta the tank.
EVERYONE I know out here with a GS400/430 or LS400/430 gets the SAME sucky gas mileage. Matter fact I know GS300's get just about the same also.
What city do you live or drive in?
But seriously, 15 MPG aint that far off from the EPA estimate 17-18 MPG if you consider the fact that MOST cars don't get the estimated MPG.
If you feel that it's misfiring, check it out, though
