Fitment Question
from these specs i wont have to pull and it ownt have the super camber retarded look...
itll be close to my original specs but i like the wider tires in bacl
well i talked to some1 and looks like i gott ago with standard disk upfront and low disk up back to fit it but my offsets should be good
my wheels are sunken up front, only 9" +27 and they clear with the low disk. i got the guy who bought my wheels to ask Work for me before i bought them just to make sure!
but Ordens are more concave so maybe you will need the standard disk for those
and yeah i talked to the guy im getting it from and he said i can raise my offsets in front and run spacers and run low disk or just run standard in front low in back..
i dont know if itll be that noticeable with stepped lips
I think he is wishing he can get the low disk instead of the medium/high disk so he can have more lip on the front rims. Generally, the low disk has a deeper lip than the mid/high disk no matter what the offset is. So, in order to clear his brake calipers, they are saying the rim style he wants require the medium or standard disk. If I'm guessing correctly, he wants the deeper lip, so ordering a higher offset in the low disk will allow him to use a spacer to clear the caliper and still have that deep lip. But, I could be wrong
hmm barely cleared with +20!? i might have to raise my back offsets a lil higher, i dont wanna mess with the body lines and pull it i just wanna shave
