Please help....CAR IDLES LOW/ROUGH AFTER CHANGING TIMING BELT
After installing the timing belt and its components, did you rotate the crank, by hand, 2 complete revolutions and verified timing before you buttoned it back up?
Take the timing cover off and verify your timing marks...
My bet is that you are off a few teeth, I hope not too many or you will have bent your valves.
good luck.
good luck.
I have a video of how to do the timing belt, not sure if I finished it though. I'm going to make a new set in the near future.
https://www.clublexus.com/forums/gs-...ing-a-2jz.html
ckasper
20
06-08-08 08:27 AM
