SRT intake with ecu on GS430! anything i need to know before install
like title says.. Directions straight forward? Reason is car is in Ohio, I'm in Tennessee. Flying back up to do my install and drive back down 600 miles.. GO CAVS!
i know i did the search, just any advice from the gurus?
the instructions that SRT provides is accurate right? becuz i thought i read something about it not being and basically i have to test the wires. if so i might have something bookmarked
will do! being im already heavy handed on my bike!
but check this out.. my ride is a 01 GS430
thought they never made a GS430 in years 98-00..? is this ok?
![](http://i40.photobucket.com/albums/e233/ps38/IMG_7919.jpg)
sorry, but that sounds like a really stupid idea. why wouldn't you wait until you got home to install it? Why take that risk in the event you screw things up, then you're stuck. Not that you're going to, since installing a cold air system is pretty straightforward, but I don't think I've ever screwed things up while working on them with the intention of screwing it up, it just happens. And always seems to happen right after the parts shop closes. Or happens when I need a specific tool I don't have.
https://www.clublexus.com/forums/2ge...srt-exact.html
hmmm, weird
if u need the directions for the gs430 here they are
post # 23
https://www.clublexus.com/forums/per...-ecu-prob.html
Install is pretty straight forward and you will know if you did not do something right long before you leave for TN (car will either not start or run like crap with CEL's). When installing the ECU, be sure to solder your connections. I would hate for you to get half way home and a crimp shake loose leaving you stranded. Do it right the first time. G/L!!!!
