Water leaking into the passenger pillar...help!!!
ok so i noticed that when it rains heavy or when i wash the car in the car wash my passenger side front pillar gets wet and begins to drip onto the carpet. possible bad seal on the windshield???
same. search for threads, its the sunroof drain line (assuming you have a sunroof, if not loucky you less weight less electronics no drain lines i guess) you have to clear it out i tried hot water it was better but i still leak. drivers side got cleared fine. i have my headliner out for a project and im waiting for rain so i can watch where it comes from. keep this thread alive or PM me, ill let you know bro
Its really hard to pin-point where the problem is comeing from. Best thing to do is sit inside while someone water the car down. From there hopefully you can find where the leak is comeing from. If it is one of your weather seal going bad look in the classifieds section. There are currently two member who are parting out their car due to accident. Maybe you can pick up some parts from them. GL
I have the same problem with water dripping from the middle of the driver side A-Pillar, I removed the A-Pillar and ran the hose over car for about 15min, the moonroof drains were clear and free flowing and then I noticed a water leak coming between the black glue used to secure the windshield to the car. about 2 years ago I had the windshield replaced and went back to the shop to complain about it, the shop will replace the windshield free of charge since it still under warranty.
