Gs headlight problems
Hello every 1,
im new to club lexus, and i recently bought a 2000 gs 300 pearl wht.
After work last nite i noticed that both passenger headlights had humidity inside them.
Can anyone here tell me y does this happen?
Do i need to replace headlights bc they r old?
Plz anyone let me noe, its strange how just the both passenger side hav humidity inside them but the left driver side doesnt.
Tnks....
Tnks....
Hello every 1,
Tnks....
Tnks....
Hello every 1,
Tnks....
Tnks....
Condensation works like this.
Hot air- touches cold surface = condensation
Fix = ventilation of space, Raising the Humidity point, or lowering Space temp.
why the passenger gets Condensation is because if you look closely hot air from the radiator is directly radiated to the back of the headlight without a shield. if you have an aftermarket air intake also will increase the amount of hot air being pulled in.
try cutting a plastic piece and using it as a sheild, check your back boots, breathers level cover, etc. Also putting cooler air behind the headlight will help. But in general the GS headlights are not that great in design when it comes to Condensation
hope this helps
****-adkt has great points that make sense. I had tons of condensation when I first bought my GS400. I removed the small rubber circle seals from the inner accent lights and brought the old ones to the hardware store and got the same size rubber seals and replaced them. No more condensation! This problem is consistent with GSs so some stuff works and other small mods don't. If it bothers you that much you may want to consider replacing the headllamp with after market projection headlamps. They are a little costly but they look freakin sweet when they are done right.
hi guys,
well noe my headlights r all dried up tnks to da sun drying them for me.i thank everyone for there help and advise. it really bothers me to c one headlight fogged up and da others not. i even restored them like two days ago.
Also where can i but wat u said to seal wat ever that is called dat causes that to happen?
im trying to keep my GS headlights stock. i mean i like after market but im going stock on my GS. i guess ill try fixing the blk rubber circle that goes around headlight.
Use silicone as a quick fix... I like the angel eyes look... I switched to them. Looks and works great, had them for over a year and the seals dry rotted a bit, called up the guy I bought them from and he sent me a new set, I gotta send him back this set (keeping a deposit...lol).
IXI187IXI
18
04-05-10 05:16 PM
