GS400 Wheel Alignment
Old 04-27-10, 05:16 PM
airahcaz
airahcaz's Avatar
Default GS400 Wheel Alignment
I had my lower ball joints replaced last year, and then a wheel alignment.
This year, horribly out of wack, so got another alignment.
Please analyze the results, seems I am at the far end of some of the allowable ranges:
Front Left Before and After
Camber -0.2 -0.1
Caster 7.2 7.2
Toe -0.3 -0.07
SAI 8.8 8.8
Included Angle 8.6 8.6
Front Right Before and After
Camber -1.5 -0.8
Caster 6.8 7.5
Toe -0.0 0.06
SAI 9.1 8.6
Included Angle 7.6 7.8
Front Before and After
Cross Camber 1.3 0.7
Cross Caster 0.4 -0.3
Total Toe -0.29 0.13
Rear Left Before and After
Camber -1.2 -1.6
Toe -0.26 0.19
Rear Right Before and After
Camber -1.3 -1.3
Toe 0.13 0.11
Rear Before and After
Total Toe -0.13 0.29
Thrust Angle -0.19 0.04
Mechanic said my steering had to be off, and after the adjustments I see that my steering wheel is straight but my steering wheel column goes from high to slightly lower, looking left to right.
Old 04-27-10, 10:24 PM
GS4_Fiend
GS4_Fiend's Avatar
The steering wheel was not straight when he did the alignment. As in the steering was straight when he was in the car, as he was adjusting the toe for the front, the steering wheel could have moved. As him to redo the alignment tell him the steering wheel is crooked to you.
Old 04-27-10, 10:59 PM
vwynn
vwynn's Avatar
question to all.. how do we correct caster? does our 2gs even have caster adjustment?? or do i have to get the SPC UCA that has the caster adjustment lol
Old 04-27-10, 11:10 PM
5t341th
5t341th's Avatar
steering wheel can be set straight. its just a matter of perfection. the data u typed up is hard to comprehend. scan the printout they gave you. you should be able to get OEM specs easily with your stock height.
theres no stock caster adjustment.
Old 04-28-10, 04:53 AM
airahcaz
airahcaz's Avatar
Well, my steering wheel is straight and I believe it drives straight, will run more tests. When I said my column is slanted, that is the part below the steering wheel, not quite connected to it directly, going into the dash. Does it matter if that is not straight?
Old 04-28-10, 08:49 AM
GS300ToM
GS300ToM's Avatar
only the spc can correct caster Sir...
Old 04-28-10, 10:41 AM
vwynn
vwynn's Avatar
SPC i must get then lol.. or new LCA that arnt bent
Old 04-28-10, 12:40 PM
GS4_Fiend
GS4_Fiend's Avatar
How did u get ur LCA bent?
Old 04-28-10, 02:18 PM
vwynn
vwynn's Avatar
The prev owner.. said the other prev owner popped a tire n hit the curb?? dunno if hes BSin or not but i wouldnt be surprised hah.
Old 04-28-10, 03:03 PM
GS4_Fiend
GS4_Fiend's Avatar
Does your car have vibrating problems ?
Old 04-28-10, 03:13 PM
vwynn
vwynn's Avatar
car pulls slight right. and has some vibration at fwy speeds (could be wheel balance?)
Old 01-02-18, 04:05 PM
Pstep
Pstep's Avatar
Default 98 GS 400 rear wheel alignment
Does anyone have an actual picture before they took apart there rear end of the adjustment lobes and what position they need to be in that's all, spare the extras just need to know what mark to set suspension to and go about my day.
Old 01-03-18, 06:55 AM
KyleH
KyleH's Avatar
I wouldn't recommend taking someone else's settings and assuming they will work for you. The toll time and wear takes on suspension parts will make everyone's settings unique as far as what is a correct alignment.
billydpowe
09-17-16 10:17 AM
DMPesso
08-14-15 01:29 PM
lexusben
Suspension and Brakes
11-22-11 09:36 AM
Lvangundy
10-03-05 05:32 PM
Lvangundy
Maintenance
04-08-03 10:33 AM
Quick Reply: GS400 Wheel Alignment
