Horizontal Headlight adjustment Help
I recently installed HID D2S 9006's for my low-beams...
What I noticed is its very easy to adjust the vertical bolts.
But the 'B' bolts for horizontal adjustment are buried so deep into the fender panels and part of the frame is in the way so you can't get a socket in there.
When I checked the positon to '0' the passenger side was dead-on.
But my driver side is way out of whack. How could it have gotten so far away from the '0' mark. I can't even get in there to adjust.
I tried using a 8mm open-end wrench and dropped it into the engine/wheel cover area down below and it has magically disappeared. Even when I was able to get the wrench on the bolt there isn't much room to swing the wrench.
How do I get in there and adjust my horizontal bolt???
And how could horizontal setting be so off from the factory setting '0'?
You can see the horizontal setting by flashing a light into the headlight housing from the outside in...
I have a 2000 GS300 non-HID..
GS4_Fiend
Lost the 8MM as it dropped down low in that area.
Any idea how to find it? couldn't see it on the engine cover...
Wow, that sucks as it is going to take alot of time to adjust that way.
I am not even sure which way to turn LOL..
thinking about projectors too!!
Anyway, found the 8mm wrench in the pan. Had to take off the ECU Cover and the air filter box for leverage to turn the 'B' bolt. Took almost an hour but they are not straight and true...
thanks folks!!
thanks folks!!
