''GS300. Thinking of going LED for my rear brake lights, questions...
Old 04-28-10, 10:02 PM
gman44116
gman44116's Avatar
Default ''GS300. Thinking of going LED for my rear brake lights, questions...
Plannin on ONLY changing the inner tails, outer brakes and 3rd/window brake lights to LED.
Will this trigger the cluster warning light?
Which of the 3 will actually cause the warning light if it does go on?
And 3rd, Is there a fix besides removing cluster bulb? I still want to have the warning light just in case a bulb actually does go bye bye..
Old 04-28-10, 10:06 PM
GS4_Fiend
GS4_Fiend's Avatar
Ok you gotta start using the search button lol.
You would need to get a resistor in order to not trigger the brake lamp indicator. But this would defeat the purpose of using less watts.
Old 04-29-10, 02:33 AM
PHML
Master Thread Closer!!
PHML's Avatar
its been discussed at length.
to answer your question....
1. yes
2. all 3
3. yes..get one with resistors (outter)...or pull / cut wire to lamp out module pin #4.
Old 04-29-10, 04:40 AM
Rich23
Rich23's Avatar
^^^ what he said... I need to do this as well...
Old 04-29-10, 06:03 AM
cjames235
cjames235's Avatar
i think he is referring to actually switching the bulbs themselves over to LED...... NOT buying the full LED lamps
Old 04-29-10, 07:00 AM
gman44116
gman44116's Avatar
Guys. Searching has been done. I always search first. I k ow the first question was redundant!
Regardless. I have yet to find a solution to question #3. Just resistor and wiring workarounds. Not a working solution.
I want the warning brake light to actually work if a light still burns out. Couldn't find a post discussing a fix for that specific issue.
For now I have found to either pull the gauge cluster warning bulb.
Buy resistors for each light (does that you need a total of 4 including the
inners)?
Pull #4 wire pin connector from harness to shut down the warning signal to gauge cluster.
Old 05-19-10, 01:15 AM
GS4CLIPSE
GS4CLIPSE's Avatar
i bought led tailights from ebay, they should come with resisters already
Old 05-19-10, 11:31 PM
istundra
istundra's Avatar
inners)?
only way for the sensor to trip is if your resistor goes out. not very likely.
edsrx350x2
RX - 3rd Gen (2010-2015)
03-25-19 07:57 PM
patrickmcb
03-28-18 05:13 AM
bgrant7
11-23-17 12:56 PM
Aristo722
05-13-16 02:10 AM
RA40
Lighting
02-09-04 02:18 PM
Quick Reply: ''GS300. Thinking of going LED for my rear brake lights, questions...
