grinding calipers
Old 05-01-10, 03:14 PM
T.K.O.
T.K.O.'s Avatar
Default grinding calipers
This was resolved.
Old 05-01-10, 08:20 PM
Mr Jokster
Mr Jokster's Avatar
you can get those special lug nuts that have a long nose. Thats what I did when I put the 5mm spacers in the rear. They taper into the lug whole of the rim so you dont need to get longer lugs Try that so you dont have to grind anything Good luck.
Old 05-01-10, 08:52 PM
speedaddic
speedaddic's Avatar
good 5mm spacers (h&R) should come with 5mm extended studs...which would fit over your centercaps because its extending the 5mm that the spacers are giving...
Old 05-01-10, 09:06 PM
Mr Jokster
Mr Jokster's Avatar
I had only one set of H&R up front with extended studs. Before I bought the matching set for the rear, I had those crappy ones you get for free from the wheel shops and used the extended nuts for those until I got the proper ones
Old 05-02-10, 04:12 AM
PHML
Master Thread Closer!!
PHML's Avatar
what calipers are these? LS400? be careful not to grind too much.
Old 05-02-10, 01:29 PM
T.K.O.
T.K.O.'s Avatar
link to these 5mm H&R spacers with extenders?
Old 05-02-10, 04:53 PM
Mr Jokster
Mr Jokster's Avatar
5mm Spacers
PandaGS300
04-07-16 06:43 AM
anonymous1
06-23-10 07:31 PM
Sffd103
05-17-10 03:23 PM
3rdelement
02-25-06 10:18 AM
Terp1962
Wheels, Tires & Brakes Forum
09-08-03 05:34 PM
Quick Reply: grinding calipers
