Pulled fender So now I have a ??? For the tire PROs
05-06-10, 08:04 PM
Ok so the story is I bought 20mm Ichiba v2 spacers about a month ago for the rear. I have 255 35 20 for rear. With this I had to roll and pull fenders for sure. Now that i have that space, what is the biggest tire i can put cause i Love the staggered (Really fat tires) looks.
05-07-10, 05:41 AM
05-07-10, 09:08 AM
Wheel specs would really help
05-07-10, 09:12 AM
if you could take a picture of the pull that would also help a lot
05-07-10, 04:00 PM
take some pics bro then we can help you better!
05-07-10, 09:59 PM
Sorry about that. Its rennen 20 x 8.5 with +35 offset
Pics will follow tomorrow
05-07-10, 11:35 PM
Hmnn that should work..I have about 2 credit cards of clearance on my 9.5 setup on 20's
05-08-10, 07:58 AM
Quote:
Originally Posted by
lexusscturbo
Well I would like to get a bigger tire setup in the back so you think a 10 would work with a 285 tire?
05-08-10, 08:42 AM
With the 20mm spacer making the ET a 20x8.5 +15? running a 285 tire? 275/30 works fine on a 10" wide wheel
285/30/20 on a 8.5" wide wheel I would not do it's going to bulge I'd do a 245/30 or a 255/30...
05-08-10, 10:40 AM
You want the fat tire look get 275/30 federals
05-08-10, 11:07 AM
05-09-10, 07:14 AM
geeznuts
What is the diff between a 275 federal or 275 falkens or 275 nakang? I thought tires were all the same!
05-09-10, 08:21 AM
Some tires run wider than others...
a 275 Sdrive will have the equivalent sidewall of a 285 standard tire
05-09-10, 10:19 AM
Yokohama S-Drive you mean? Are they loud on those large wheels?
05-09-10, 12:26 PM
GS4_Fiend
yeah the Yoko's run meatier than they look; FK's are also a bit wider(not by that much though), nitto's run wide as well...
avs20
07-02-14 05:18 PM
Outrage
07-15-13 03:24 PM
kbh
08-19-09 09:20 PM
Johnson 1
06-08-07 05:40 AM
Ag02M5
Wheels, Tires & Brakes Forum
04-23-02 04:29 AM
