Automatic Steering wheel adjustment.
Any one know if you can disable the automatic steering wheel adjustment feature. Everytime I get in/out my GS400 the steering wheel adjust. I like to turn that feature off. Thanks.
Exactly, , I know it will eventually break so I'd like to disable it, I don't have it in my wifes es330 and its not a feature I really desire in my GS400. I'm kinda of scared it will break and be stuck in a position that will force me to pay the dealer a lot to fix.
If you're really against it, your only bet is to go through the dealer on that one, as its a C BEST option. They will charge you though. Call around a few dealers beforehand. Not sure if they charge per C BEST change, or if you can do a bunch at the same time for the same price, but I think it's like $50-70.
It CAN be disabled easily by DIY.
Pull off the cover (few screws) below the steering wheel, look for a small control box attached to the steering rack and it will have 2 lots of wires.
You should find 1 connector with 2 black wires. Short these together. This will stop the steering wheel from always returning to the park position. You keep the reach/rake part working
Get a Scotch-lok connector and open up the 1/2 closed second channel if you dont like the idea of stripping wires.
http://do-it-info.com/scotchlok.htm
To prove to yourself that this shorting is correct, get a multimeter to these black wires and you will see that they short when you put the key into the ignition.
e-man
09-11-07 11:55 PM
