Debadging Help!
Hey guys, So after the mishap with the install of my rear differential since i pretty much wasted the whole day i wanted to accomplish SOMETHING. So hey i thought why not debadge the trunk it sounds pretty easy and wont take too long. Got the emblems off and now im stuck with this. I've tried everything, WD-40, Goo gone, household cleaner. This stuff wont budge, Do you guys have any ideas of help to get this adhesive off my damn car!! PLEASE!!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
yeah man i used goo gone and elbow grease and then had it buffed out when i was done. use your finger nail to scrape off all of that sticky glue and then use the goo gone
Dude... Just rub the **** out of it after you heat it up. Don't be afraid to drench it in Goo Gone. Just make sure it doesn't get on any plastic and you'll be good.
Why wet sand when removing an emblem?!
Goo gone or WD-40 works as well. Make the glue soft and it comes off easily with a little bit of rubbing. If you use WD-40 make sure you wash your car afterwards.
