Removing painted on pinstripe from your GS
#31
Be careful fellas....
I copy/pasted this thread from the Autopia detailing forum , it's about the Lanka touch up product generally , but these few posts specifically center on the use of lacquer thinner on automotive paint and one of it's main ingredients-xylene, which can and does damage some clearcoats. Bad thing is, it doesn't happen right away, but can crack/check it over time.
I wanted to tell you this, as it's something I've known about for a while being a pro detailer, but I wasn't sure anyone would take me seriously since some of you have found no damage from using it. I feel it would be wrong to look the other way on this , and wanted to inform you, not to scare you. Hopefully, you guys that did already will be allright a year from now. But if you start to see tiny cracking/checking in a few months...
The good news is some cleacoats suffer less than others from it, so maybe Lexus paint will be ok. Don't worry about it till you have to I guess. Cheers....and, don't shoot the messenger!
FROM AUTOPIA.COM:
FROM AUTOPIA.COM:
Lacquer thinner will attack all automotive paint some faster than outhers so be careful.
Carguy are you going to paint the hole hood or just the pits?
If the pits are not to deep they can be removed by compounding them out with a rotary than a pollish. If they are deep the only way to remove them would be to wet sand the hood then compound it, but that may remove to much clear coat.
__________________
Andre'
06-05-2002 04:27 AM IP: Logged
ShowroomLincoln
Super Moderator
Andre' is right, don't use Lacquer Thinner. Many of the Lacquer Thinners contain xylene which will crack and "check" the film build. Even one application of this can cause clearcoat failure down the road.
__________________
Dedicated to the relentless pursuit of Detailing perfection.
06-05-2002 02:35 PM IP: Logged
Contributing Member
quote:
Oh dear.....
I guess I'll find out won't I?
__________________
Brian
Silver 1992 Nissan Maxima 4DSC - 2xAIO, 6xSG, #26, S100... awaiting the sweet scent of spring...
The Definitive PC Accessorizing Thread The Relative Abrasiveness of 3M stuff thread
VetteHead
Enthusiast Detailer
Lacquer thinner and rubbing alcohol will mix, so if your concerned that the thinner is too strong, mix it about 1/2 and 1/2 with rubbing alcohol. Used to do this years ago for modeling..
The Langka/Mothers products are far more than lacquer thinner. Use lacquer thinner at your own risk since damage may occur.
The $30 price mentioned for our Paint Chip product was in Canadian $, which are different than American $. Seems like average (US) retail is about $15-16 if I remember.
__________________
forrest@mothers.com
__________________
Andre'
ShowroomLincoln
Super Moderator
__________________
Contributing Member
Oh dear.....
__________________
Brian
VetteHead
Enthusiast Detailer
__________________
forrest@mothers.com
Vansibel
Automotive Care & Detailing
13
05-06-15 01:58 PM
fetalsono
05-03-03 05:53 AM
