Turned 20... MODS to come
Old 09-01-10, 11:28 AM
  #211
sakataj
sakataj's Avatar
UPDATES needed or unsubscribing
Old 09-02-10, 12:06 AM
  #212
Measured
Measured's Avatar
You make it appear as he owes it to you or you won't pay attention to his car. I can understand where the OP is coming from and when he has the time I am sure he'll update you and everyone else as needed.
Old 09-02-10, 08:41 AM
  #213
speedaddic
speedaddic's Avatar
LOL...Brian you're so threatening!
Old 09-02-10, 11:27 AM
  #214
sakataj
sakataj's Avatar
well since i have been talking to OP bout his car from day one of him saying he was doing this, HE WILL KNOW I WAS KIDDING WITH HIM WHEN HE DOES COME BACK...he doesnt owe me anything nor anyone else on here. you understand huh...lol ok, im not even gonna bother on this one. cool, btw WELCOME to the club
i know im a menace....
Old 09-02-10, 11:51 AM
  #215
NVTHSLEX
NVTHSLEX's Avatar
LOL, hold on a little while longer...
I have been going back and forth with CL members with pms.
Mainly because the airride fuse blew twice. So I will need to upgrade the wiring to a 4 awg. And run 2 (30 amp) fuses.
And at the same time, I am getting a grounding kit done.
This will be done on Saturday, and I can get pics of the work being done in order to keep this thread going...
Old 09-02-10, 12:41 PM
  #216
sakataj
sakataj's Avatar
i gotcha hameed, how are things? whats causing the air ride to blow? you could even go to 0 gauge wiring, it will work out alot better ESPECIALLY for the grounding kit.
Old 09-02-10, 01:08 PM
  #217
NVTHSLEX
NVTHSLEX's Avatar
With the boosted GS I cant be happier, well I would be with better milage .
But thats what happens with increased power, got to sacrifice something...
The driveabilty is great, just very few minor minor things have to be ironed
out in the tune. Along with the cold start, but with Jeff's help it should soon reach perfection or close enough to not notice.
Anyways;
Well what I have understood about the arride setup and wiring is that:
1) Two compressors
2) Currently have 8 awg wire, and 10 awg wires (These will be upgraded)
3) The fuse placed in the fuse holder kept blowing, this is because of the
current going through was heating up the seals along the inside of the
fuse.
Which makes the fuse loose its flow of electricity, therefore compressors
are not kicking in.
Now I have looked into the following (Help from Mr. Jokster & Speedaddic):
Running 4 awg wires, with a 60 amp fuse, a distribution block,
with 2 (30 amp) fuses. Along with 2, 40 amp fuse relays.
I am thinking about putting in a breaker, but not sure yet.
Then of course, which will also be done Saturday is the grounding kit with
4 awg wires.
I will look into 0 awg, but would that not be overkill ?
What do you think Brian ??? And anyone, since Saturday is only a few days away.
thanks
Old 09-02-10, 01:52 PM
  #218
sakataj
sakataj's Avatar
Anyways;
1) Two compressors
fuse.
are not kicking in.
4 awg wires.
thanks
no thats def a great upgrade with the 4 awg wire, the 60 amp, distribuiton block, the 2 30 amps, and the 2 fuse relays.
but i DEF dont think 0 gauge is overkill, you have a stereo system, a air ride kit, and a big motor setup. trust me 0 gauge DEF wont hurt NOR would upgrading your alternator. your not on the OEM battery are you? if so,i would recommend upgrading that also. anyways im gone for the day....def keeping my eyes on this hameed
Old 09-02-10, 02:13 PM
  #219
GS4_Fiend
GS4_Fiend's Avatar
Since you are doing it all by yourself, going from 4 to 0 gauge wont cost much.
Old 09-02-10, 02:39 PM
  #220
JiBBeL
JiBBeL's Avatar
I read this as:
I have been going back and forth with CL members with pre-menstrual syndrome.
and let loose a good belly laugh
Old 09-02-10, 06:37 PM
  #221
NVTHSLEX
NVTHSLEX's Avatar
Thats true, I guess it would be better to run more on the safe side.
I may also need to upgrade the alternator sometime down the road, and defiantely get an upgraded battery.
I just replaced my old oem battery with a new one, in March.
But before winter hits my area, I will get an optima or a kinetik battery.
Actually, Im going to an audio shop that also does air ride/hydrolic work...
I will also be working on it, along with the shop's technician. So I will have to probably pay for an hours worth of labor.
Originally Posted by JiBBeL
I read this as:
Now how could you not know that pms on forums
= private messages ...
Hopefully not many more people read it as the way you did, or else we will need to find a different acronym for private messages.
Old 09-02-10, 06:43 PM
  #222
ThomasGS4
ThomasGS4's Avatar
I read it as Private Messages...lol pre-menstrual syndrome?! Wtf?!
Old 09-02-10, 07:36 PM
  #223
sakataj
sakataj's Avatar
he knows what it means u two, i believe him to be referring to me, in regards to this thread. Post # 112 through Post # 114
https://www.clublexus.com/forums/sus...zen-diy-3.html
Old 09-02-10, 08:14 PM
  #224
NVTHSLEX
NVTHSLEX's Avatar
LOL, everyone knows pms is private messages.
It was a play on with the acronym; at the same time it can be taken into context with the frequent suggestion for Updates...
And I saying I will update...
For those that have been following the thread.
But this Saturday, I will take pics of the wiring, and grounding kit.
Also get some decent shots with the car slammed.
Old 09-02-10, 09:31 PM
  #225
speedaddic
speedaddic's Avatar
keep the power separate from the stereo and Airride...when those compressors kick on, they draw a lot. You don't want any kind of surges...trust me.
Quick Reply: Turned 20... MODS to come
