Turned 20... MODS to come
#256
Second battery and isolator and alternator will be done at the same time.
I definately going to take all the advice I got from you, and Brian.
During the photoshoot, I never turned the car off, just let it idle. Since we went to about 6 locations. There was no point, turning off the car and starting it every 30 min. or so. Wasted a fair bit of gas just idling...
Yea I already killed one battery with the compressors while the car was off.
Defiantely do not want that to happen again.
thanks
#258
Uncalibrated sensors...
Full tank = 80 psi compressors are off...
Full down and full up reading of tank becomes 70.
Do it again psi in tank, drops to about 68 then compressors kick back on and it takes about 15 seconds to hit 80 psi again and stop.
I think the compressors just come on if they are below 68 psi reading and stop when tank is full....
#259
Time to bring this thread back ALIVE....
Mods to come:
For dual battery setup, and grounding.
21 feet Stinger HPM Series 0 Gauge Clear Power / Ground Wire
20 feet Stinger PRO Series 4 Gauge Red Power / Ground Wire
10 feet Stinger HPM Series 4 Gauge Gray Power / Ground Wire
2 Stinger Inline AGU Fuse Holder
1 Stinger 80 Amp AGU Shoc-Krome Finish Fuses
1 10 Stinger 0 Gauge Ring Terminals
1 10 Stinger 4 Gauge 1/4" Ring Terminals
1 Stinger 8 Gauge Crimp Ring Terminals
1 Stinger Inline ANL Fuse Holder
1 Stinger 200 Amp Battery Relay
1 Stinger 250 Amp ANL Shoc-Krome Finish Fuse
1 XScorpion Digital Battery Terminal
2 Stinger HPM Battery Terminal
1 XScorpion Gold Finish Battery Terminal
DCpower XP series HO alternator
In the works, still being made is a custom two tone interior, with double diamond stitching...
Pics to arrive shortly....
Mods to come:
#262
Thanks ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Other Misc. parts are HKS grounding kit, and
Ultra White LED vanity lights to complete the interior led lighting... awaiting shippment.
Date of install: Approx April 30- 2nd week of May...
#267
LOL; thanks
It would be insulting if only it was true, but since its not it holds no
value. Well to me...
I know that I need to change the rims, and body kit, but that will happen when there is more cash flow.
In the mean time, its cool the way it is.
#270
As for those who are wondering why these items have not been installed yet; they will be.
Project starts May 26th, this thread will have plenty of pics showing the installation of the dual battery and all the parts mentioned above.
Along with the two tone leather interior
