Turned 20... MODS to come
Thanks man
thank you, cant wait to see your ride's end result.
Im leaving in less than a week, and should be in Dallas by the 6th of june.
Thanks, ohh it feels great having a GS
thank you
Thanks man, well parents bought me the car when I was 17. Helped with the mods in the beginning then I started modding even more. Parents were like; if you keep modding your going to have to pay for it.
For this present it was paid 50/50. Gotta love em
thank you
I thought I would put the list of parts later on, as the build progresses.
But I guess anticipating for the pics, is a teaser itself![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
So the list:
Engine: ( thanks to Jefftsai)
- 2JZ-GTE Engine
– Ceramic chrome coated: Valve covers, intake manifold, throttle body, water pump housing, upper water neck.
– 2JZ-GTE Stainless Steel Tubular T4 Manifold
- AEM EMS modified to work with the GS.
– New Toyota timing belt, all engine seals(valve cover gaskets, cam seals, rear main seal, etc).
- 3 row aluminum radiator custom modified to fit in GS.
- Reinforced silicone upper radiator hose.
- Aluminum coolant overflow tank custom built to fit car.
- Aluminum power steering fluid tank custom built to fit car.
- Custom machined fuel rail.
- Precision 1000cc injectors.
– Stainless braided fuel lines and fittings
- Walbro high flow fuel pump 255lph
- Aeromotive fuel pressure regulator.
- Intake pipe with 4" inlet 9" long AEM Dryflow filter
– HKS SSQV Blow off Valve
- 60mm wastegate
- Custom fabbed 3” downpipe
- Custom fabbed midpipe
- Custom fabbed 3" intercooler piping
- HKS 32x12x3" front mount intercooler
- HKS Cam Gear
- Hayden Tranny cooler
- Flex-a-Lite Slim Fans
- Built automatic transmission. Extra clutch packs, upgraded to race clutches, upgraded sprag, upgrade valve body.
-T4 turbo blanket
- 3.76 supra LSD
- L-tuned mufflers
- Comp triple ball bearing Turbo 6765
- Polished turbo housing
Electronics:
-HKS boost controller EVC-S
- HKS turbo timer type 1
- Dash Daq (dont like gauges sticking out, this is the perfect solution)
Brakes:
-Upgraded cross drilled and slotted rotors and upgraded pads
( low on funds for a big brake kit, later on I will get one... )
Airrunner:
(Thanks; everyone who helped me with my decision and answering all questions related to it Mr. Kenji, 3GS404, skperformance, aristo228,viptint,BLKonBLK98,PHML,GS300RICH, MrExecutiv, etc... and Purchased from Vendor TrendyTodd)
-Airrunner kit
-2nd compressor
-water trap
-Digital dakota display w/5 sensors
- 2 port splitter to run the 2nd compressor
- Upgraded wiring lines
Retro:
-Q45 projectors
- will be having the housings painted DWP
-luxuryMods brackets
MISC:
-TRD sway front and rear
-Daizen polyurethane bushings control and caster arms
-Daizen steering wheel bushings
-Interior LED package (Ultra Bright White):
2 pairs courtesy lights
1 pair front map lights
1 piece front dome light
1 pair rear dome lights
Also thanks to Mr. Jokster and CarbonGS for answering many of my questions...
So the list:
- 2JZ-GTE Engine
- 60mm wastegate
- HKS Cam Gear
-T4 turbo blanket
- 3.76 supra LSD
- L-tuned mufflers
Electronics:
Brakes:
Airrunner:
-Airrunner kit
-2nd compressor
-water trap
Retro:
-Q45 projectors
MISC:
