Turned 20... MODS to come
#33
I thought I would put the list of parts later on, as the build progresses.
But I guess anticipating for the pics, is a teaser itself![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
So the list:
Engine: ( thanks to Jefftsai)
- 2JZ-GTE Engine
– Ceramic chrome coated: Valve covers, intake manifold, throttle body, water pump housing, upper water neck.
– 2JZ-GTE Stainless Steel Tubular T4 Manifold
- AEM EMS modified to work with the GS.
– New Toyota timing belt, all engine seals(valve cover gaskets, cam seals, rear main seal, etc).
- 3 row aluminum radiator custom modified to fit in GS.
- Reinforced silicone upper radiator hose.
- Aluminum coolant overflow tank custom built to fit car.
- Aluminum power steering fluid tank custom built to fit car.
- Custom machined fuel rail.
- Precision 1000cc injectors.
– Stainless braided fuel lines and fittings
- Walbro high flow fuel pump 255lph
- Aeromotive fuel pressure regulator.
- Intake pipe with 4" inlet 9" long AEM Dryflow filter
–SSQV Blow off Valve
- 60mm wastegate
- Custom fabbed 3” downpipe
- Custom fabbed midpipe
- Custom fabbed 3" intercooler piping
- 32x12x3" front mount intercooler.
-Tranny cooler
- Built automatic transmission. Extra clutch packs, upgraded to race clutches, upgraded sprag, upgrade valve body.
-T4 turbo blanket
- 3.76 supra LSD
- L-tuned mufflers
-Precision Turbo 6765
Electronics:
-HKS boost controller EVC-S
- HKS turbo timer type 1
- Dash Daq (dont like gauges sticking out, this is the perfect solution)
Brakes:
-Upgraded cross drilled and slotted rotors and upgraded pads
( low on funds for a big brake kit, later on I will get one... )
Airrunner:
(Thanks; everyone who helped me with my decision and answering all questions related to it Mr. Kenji, 3GS404, skperformance, aristo228,viptint,BLKonBLK98,PHML,GS300RICH, MrExecutiv, etc... and Purchased from Vendor TrendyTodd)
-Airrunner kit
-2nd compressor
-water trap
-Digital dakota display w/5 sensors
- 2 port splitter to run the 2nd compressor
Retro:
-Q45 projectors
- will be having the housings painted DWP
-luxuryMods brackets
MISC:
-TRD sway front and rear
So the list:
- 2JZ-GTE Engine
- 60mm wastegate
-Tranny cooler
-T4 turbo blanket
- 3.76 supra LSD
- L-tuned mufflers
Electronics:
Brakes:
Airrunner:
-Airrunner kit
-2nd compressor
-water trap
Retro:
-Q45 projectors
MISC:
im assuming you bought jeff's old motor setup he had? i hope you got someone up there to work on this down the road (not that it will be messed up) but should the need ever arise (aka beating on it or something lol) or maintenance or anything.
depends on WHEN you ordered them...i just got my control arm bushings in and it took me 56 days total i think to get them
#35
you know we do ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I do intend to see where the money went from time to time ("aka beating on it")
For the bushings I think I am extremely lucky, I never got an email reply that I sent out 2 weeks ago. But I placed an order for the Daizen control arm bushings and steering wheel bushings on May 30th, order processed by the 1st of June, and Jeff should have it at his house by today (3rd of June). A total of 5 days from process to arrival.
Beats... 56 days of waiting....
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
thanks; ...lol
#37
Yea That would be me.... Well not many people around my area know much on tuning an AEM standalone. But maintenance (o2 sensors, spark plugs etc...) can be covered.
I do intend to see where the money went from time to time ("aka beating on it")![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Beats... 56 days of waiting....![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
yeah it sure does beat waiting....guess he had some in stock when YOU ordered...i had to wait on him to re-order some.
#38
Then I'll have a video done when I am back home.
Yup TM had them in stock, got the last one too. Next shippment is in 2-3 weeks.
#41
Congrats, that is a hell of a setup. Throw on a Vertex kit and it will be Jeff's car all over again.
Make sure you record the reactions of every person that you give a ride in your GS when its done, including your own reaction. I remember I was giggling like a school girl the first time I went for a spin. That would be a fun video to share with all of us
#42
Pics of the parts should be coming up soon. I asked Jeff to help me update the thread with the pics.
Will do...
Oh yea, first time having a powerful car. Can't wait....
The reaction you had, will be the same that I will have, or anyone else for that matter.
