GS with IS Wheels
GS with IS Wheels
I was wondering if anyone has tried to put the 10 Spoke IS Wheels on a Second Gen GS. I am trying to move down from a 19 inch wheel to a 17 inch since I'm going to college in the fall (the city will tear my rims up) and the 10 Spoke IS wheel is my favorite stock Lexus Rim.
Is it 215/45/17 ? I had the 07, I think 5 spoke.
If so... I had those awhile back. 215/45/17 tires, if that's what you're getting.
pros:
better gas mileage
cons:
stopping distance is greater
accelerates slower
high speed turns are less solid
view from behind the car looks like you're rolling with doughnuts
- Thinner width tires do this unfortunately.
pros:
better gas mileage
cons:
accelerates slower
Well my rims are 8.5 inches wide and I was looking at http://www.finishlinewheels.com/LEXUS/IS350/2008/ (the top one) which is 8 inches wide so I wouldn't think it would be too different. I like the 5 double spoke wheel too, but not as much as the 10 spoke. The 5 double spoke come in 18x8.5.
I Photoshopped a couple pics to show you guys what I'm talking about.
17x8 in 10 Spoke Rim
18x8.5 or 18x8 5 Double Spoke Rim
I'm not sure which I like more and I'm not sure if an 18 inch rim is going to help very much (compared with my current 19 inch rims) with nasty roads.
well im pretty low, those are my pics in that thread posted..im lower now. the rear needs like 35mm and the front almost the same..keep in mind i have about -3 degrees of camber.
as you can see they are pretty sunk..im buying bolt on spacers this week for the rear, im doing 35mm or 38mm. if you want to be safe just do 25mm or 30mm, anything will look better than this lol
Thanks! I think I'll probably go with 25mm in the rear and 15mm in the front. I was thinking that 25mm might be too much for the front, no? I'm not going to slam the car, probably run NF210's as the gs is my daily driver.
Here's a pic right after i threw them on the car this past Saturday, I'm really liking them so far. The rims that were on the car when i bought it were disgusting..
