Need help with stretching my tires.
Yes. You'd have to have someone who actually knows what they're doing in terms of tire mounting to get it to seat, though.
PS: For all the neigh-sayers out there, I have 225/45/17 on a 10.5 and I've seen a 225/40/18 on an 11". The 19" wheel would be no different sans the shorter side-wall height that makes it a bit difficult to seat compared to the others.
PPS: Are you trying to fit those wheels on a 2GS?
My old setup I have 10.5" with 235/35R19 front and 12" with 275/30R19 rear.
In the front I might have gotten away with a 225/35, so you might barely make it on an 11" but I wouls stick with 235. In the rear I was definitely maxed out. The bead of tire didnt even touch flange of the rim. I could fit 2 credit cards. Some tires the side wall can stretch a little better than others. As c4lvin said. These are going to be damn hard to seat.
Here is a post from the VipStyleCars forum. Hope this will help.
Originally Posted by widebody_Q
19x11.5 -14 up front 235/35/19
19x12 -8 in the rear 265/30/19
Massive Pull front and back
This is my rear. Fenders are getting pulled an extra 3mm and repainted sometime after november 12th. Then the real will be as nice as my fronts.
JEFFOS69
12-08-10 06:24 PM
