GS300 Fog Bulb replacement question
On a 2nd generation GS, do you have to replace the fog light bulb from the side well or can you simply remove the fog light housing in the front and swap the bulbs out that way?
I found a 'DIY' for 3rd generation which says you need to go through the side well, but I thought I read somewhere that 2 GS you can just pull off the fog light housing.
