Creaking Moonroof TSB
Does anybody have a copy of the TSB that deals with the creaking moonroof? I have seen a few references to it, but all of the links have been outdated.
Also, what needs to be done to fix this successfully? I recently bought a used GS400 and would like to get the info, before I take the car to the dealer.
Thanks!
Axel
Thanks!
Axel
I have brought it to my dealer's attention already, and they checked and told me that i already have the updated housing or fitting parts (might be something worth asking for on your car), so not much they can do. They did re-lubed the entire sunroof area, plus my front windows, cause they were all making little noises. It helped for ~2 weeks, then I think it came back. I am thinking next time, i may ask for replacement pending on how the noise develops in the next few months.
I can't hear the creaking now, all i can hear is the Ltuned mufflers that I just put on, so that may be your other solution
MY RX300 HAD THE SAME PROBLEM
Last week I took my wifes RX300 (01) to the dealer for this creaking sound that was driving me crazy. They told me there was a GS repair kit for this exact problem. Sure enough that was the fix. They replaced the black plastic trim on the inside of the sun roof. Not a peep since.
I have the same problem; lucky my car is still under the warranty. I took it to the dealer, they told me most of the Lexus have that problem “Too much heat from the sun & the plastic around the sun roof shrink”
After the service the sound stops.
Tony
Tony
hey the sc has this problem too, i also noticed that if i slam my door u can see the sun/moonroof bounce up from the air pressure, they need to make these things a little sturdier.
for a solution i just turn the volume **** clockwise.
atrac7
03-22-17 04:15 PM
