A/C Blowing Hot Air!
Old 06-11-10 | 03:20 PM
99GS4's Avatar
99GS4
Default A/C Blowing Hot Air!
I drove to work this morning and the air conditioning worked fine, when I left work nothing but HOT air. I checked fuses, checked filter, refrigerant is full, the compressor is engaging, did diagnostic check on A/C and code "00" came up (which means normal)....
Any Ideas?
Thanks in advance.
Old 06-11-10 | 05:15 PM
99GS4's Avatar
99GS4
Originally Posted by Turbo_LX
Was the switch on hot?
The temp is set at 70...
Old 06-11-10 | 06:14 PM
casey_c's Avatar
casey_c
Is it blowing hot on the passenger side too?
Old 06-11-10 | 06:20 PM
MobbinVIP's Avatar
MobbinVIP
This happened to my mom's Buick
they checked everything that you did &
even flushed the A/C system and refilled all the fluids,
everything was fine but still didn't work.
then I took it somewhere else were there experts on A/C's,
they removed glove box
& behind it was an "switch" that controls an arm for hot & cold
(or something like that) & they flipped the switch on cold
now the passenger side is always on hot lol
Cost to much to fix for a 99 Buick
Hope this is not your problem
Old 06-12-10 | 12:35 AM
MrExecutiv's Avatar
MrExecutiv
does both sides blow hot air or just one side? It could be the expansion valve causing your problems.
Old 06-12-10 | 08:01 AM
ElitistK's Avatar
ElitistK
your servo motor is out.
Old 06-14-10 | 06:16 AM
99GS4's Avatar
99GS4
Hot on both sides...
Old 06-14-10 | 06:17 AM
99GS4's Avatar
99GS4
Is it easy to get to the servo motor? How can I check it?
Old 06-14-10 | 10:51 AM
ElitistK's Avatar
ElitistK
https://www.clublexus.com/forums/gs-...ou-search.html
go down to interior, and DIY servo motor replacement.
check the FAQ next time you make a thread.
bigcat88
12-19-16 01:24 PM
bighogman
08-01-15 07:05 PM
wise2k
06-27-13 08:17 AM
sung35
07-04-11 01:08 PM
velocity12
07-04-11 11:09 AM
