Precut window tint, need your opinion
Old 06-15-10, 01:35 PM
BrentGS
BrentGS's Avatar
Originally Posted by YviE
And the soapy water is not gonna leave traces when it dries?
If you clean the window like your supposed too it shouldn't
Old 06-15-10, 03:43 PM
TopRamen
TopRamen's Avatar
I've done this before.
Materials needed:
spray bottle with soapy water - I fill up the bottle and then add 5-10 drops of dish washing soap in.
flat plastic scraper - size: 3x8 and/or 4x9 - you use this to scrape all the water out between the inside of the tint and the window
heat gun - this is for your back/rear window tint - you need to mold it because of the curvature
Note:
eBay sellers sell a pre-cut that is a perfect fit.
if you need help or advice, private message me.
Good luck.
Michelex (01-24-17)
Old 06-15-10, 04:09 PM
MobbinVIP
MobbinVIP's Avatar
Materials needed:
Note:
Good luck.
+1
I have seen my friends do there cars like this
Came out great at the end
GL
Michelex (01-24-17)
Old 06-15-10, 05:01 PM
BrentGS
BrentGS's Avatar
Materials needed:
Note:
Good luck.
Also a razor blade helps to scrape off tiny sediment or whatever particles are left.
Old 06-15-10, 05:05 PM
pingu
pingu's Avatar
I would suggest you watch as many youtube videos as possible to see how professionals apply the film.
Old 06-15-10, 09:48 PM
YviE
YviE's Avatar
Thanks for the tips, guys!!
I'm going with a precut kit. Will probably buy it next month. I'll keep you updated.
Old 06-16-10, 08:46 AM
upstateGS4
upstateGS4's Avatar
don't tint the side windows yourself with one type of tint then pay a pro to do the rear window if you want it to match. regardless of % of shade and whether or not you go with the "same" for both, you won't get a match. every brand is different. every brand also ages differently. even made of different materials. some have ceramic in them. some have metal. some can f up your gps nav reception due to the type of reflective elements used to make certain shades.. but you do get what you pay for. you ever seen those cars rolling around with the disgusting faded purple peeling tint? those are the guys that went with the $10 roll from the auto store instead of having a pro job done with high grade materials.
Old 06-17-10, 11:11 AM
samster
samster's Avatar
guys! soapy water = very little soap and mild soap not dish washing detergents i use johnson and johnsons no tear! spray bottle should be full and only use a few drips of shampoo ratio should be like 99% water 1% mild soap, and always cut with a razor blade made from stainless steel so it doesn't cut your windows. i've had guys bring me ebay precuts, computerized precuts or whatever, i preffer to use reg paper. the pre cuts come over sized and still need to be trimmed and it's harder to edit an already altered piece of tint then starting fresh.
items needed
#1 = some type of plastic applicator or bondo pad
#2 = spray bottle
#3 = heat gun
#4 = baby shampoo
#5 = bounce paper for rear window
#5 = bountys
#6 = sharp *stainless steel* blade
#7 = also a good drop light to cut your rear tint with
the side windows should be cake, have fun with the rear >=P
ohhh and don't forget #8 STEADY HANDS!
Old 06-17-10, 11:22 AM
YviE
YviE's Avatar
Sorry, but what is bounce paper? And what its use for?
Old 06-17-10, 12:50 PM
samster
samster's Avatar
the bounce fabric softerner sheets u put in the dryer, it's for your to wipe on your rear glass for your to dry shape your rear glass tint with a heat gun
Old 06-17-10, 11:12 PM
istundra
istundra's Avatar
Originally Posted by IXI187IXI
eh precut tint is so much harder to put on because you have to have it exactly lined up for it to look good. where as a large sheet, you can just cut to fit. instead of buying precut, why not order a roll of tint?
pre-cut... ive had it before.. they installer was off by a few MM... so u can so tell it was tinted at the very edge...
ended up ripping it off cuz it was crooked... and also wrinkles.
2nd time around had it hand cut.. now all the way to the edge.. and looking good.
Old 06-18-10, 12:43 AM
YviE
YviE's Avatar
I'm still undecided whether to get a roll or a precut kit.
I'm gonna talk about it with my buddy, see what he thinks.
Old 06-18-10, 04:17 AM
jeepandlex
jeepandlex's Avatar
Hi,
I can have the car professionally tinted, but that would cost me 500 euro (approx. 600 US$). They do excellent work though.
So I'm exploring other options... and found this:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Precut window tint kits! Has anyone tried such kits? How is the fit?
I have a friend who does a more than decent job at tinting windows that don't require heat-shrinking (so he could do the sides). And then I can always have the rear window professionally tinted.
Please give your opinion.
Thanks
personally, I'd get the precut. You've got all you need listed for you here. I used precut on my jeep because my windows come out great with no bubbles or anything, but no matter how much time I take trying to cut edges, it looks like crap with the window down. Precut, you just have to account for the rubber seal and you're good to go!! also, any what ever you decide to do the tint will be "side" specific. You have to peel off an edge and spray the hell out of the sticky side. Try a small window first... And it'll just be easier if you take off the door panel....only a couple screws and clips. I have the tint right now in a scroll. I'm just waiting for my vacation so I can install it on my chick's gs. "it's not even my car and I'm throwing money at it!!"
Old 06-18-10, 05:08 AM
YviE
YviE's Avatar
jeepandlex, which precut kit did you get?
Old 06-18-10, 01:50 PM
YviE
YviE's Avatar
What did you have the most trouble with?
Quick Reply: Precut window tint, need your opinion
