aftermarket OE Fender/ bumper quality?
Fitment is always off in one way shape or another as far as where it should bolt up to otherwise they are a good means if replacement I use to do body work n paint so I've used plenty of aftermarket pieces and it seemed like they needed a little adjustments here and there but overall ok to use
The guys above nailed it. I had my hood replaced w/ a OEM one and an aftermarket left fender w/ OEM driver side headlight. Fitment was slightly off BC of the fender. Had to do a little work at my friend's shop - although looks excellent - but it was not as "flawless." But you can't tell unless you do a close examination.
