need help rear disc rubbing
Old 06-21-10, 08:20 PM
kailah00
kailah00's Avatar
Default need help rear disc rubbing
need help i just changed my brakes and my rear disc are grinding with e-brake sheild is their anything i can do to fix this problem or has anybody had this problem before
Old 06-22-10, 09:38 AM
GS300ToM
GS300ToM's Avatar
r u sure u put it in right??????
Old 06-22-10, 10:46 AM
Infamous 1
Infamous 1's Avatar
Are you sure that the parts you replaced them with are the correct ones?
Old 06-22-10, 12:10 PM
PHML
Master Thread Closer!!
PHML's Avatar
bend the shield back to stop the rubbing?
Old 06-22-10, 12:16 PM
pwesseler
pwesseler's Avatar
+1 (you probably bent it accidently while servicing your brakes)
Old 06-22-10, 12:56 PM
nar8ta
nar8ta's Avatar
This may not be your problem but this was the fix for my car. I was hearing a grind sound when i jerked the steering wheel or went around a curved road.
This should be a sticky!!!! (good info)
https://www.clublexus.com/forums/sus...ggestions.html
Old 05-22-11, 05:48 PM
kailah00
kailah00's Avatar
that was the problem thanks
openlishy
01-22-13 01:01 PM
Quick Reply: need help rear disc rubbing
