Is it common to smell something when you accelerate hard?
I have read in a couple of threads that a funny smell when accelerating full throttle are symptoms of a catalytic converter going bad...
But none the less, most cars that I have had or driven, have had a weird smell with hard acceleration. Is it because I drive in a city and the exhaust system isn't being blown out the same way a car that is usually on a highway is?
BTW i got a code for my CEL that my cat converter is going bad. But I really want to know if its the Cat converter...
At my mechanic shop, there are a lot of LS' and GS' that have cat converters going bad... I find it weird because most of you on this forum say that a cat should last the lifetime of a car...
my car only has 120k miles on it...
Moderator - Electronics Forum
What error codes are you getting? I had a P0420 code. The stealership was very insistent on replacing the converters. It turned out to be the post cat o2 sensor that was getting weak.
When I told the stealership that I had replaced the o2 sensor and that the problem was fixed, they had a very sour look on their face. They wanted the 3000 that was quoted for parts (converter/o2 sensor/labor) when all it took was a 150 dollar o2 Denso sensor.
If you have a scan tool that can read the datastream, you can monitor the voltages for the sensor.
It is normal to get some smell because when you punch, the car runs a bit rich from the factory so it is normal.
But if the car is throwing a code, follow Percy's advice. If the O2 sensors voltage is not steady, it will throw off the AFRs and you will be running very rich. Goodluck
yea i have seen smoke puffs and smelled some funky stuff when doing hard pulls in my car and with other people's car. One time I was trynna keep up with this Porsche that was like an 05 and when he drove off a small amount of black smoke puffed out and you could smell the oil burning. In case you didnt know oil burns a lot faster when you drive fast. Also ur car isnt exactly a baby so your o2 sensor might be dead thats in front of your cat. GL
I get a smell when I press out on gas... But I though it was my K&N...
Kosi, Hit me up, man I will read the code for you...
Percy, the sensor they replaced is one of your bank 1 sensors, Am I right? I believe that "post" is after the cat and that is (should be) bank 2 sensors...
Altogether, our cars have 4... Bank 1: sensors 1 and 2 (driver/passenger sides) and Bank 2: sensors 1 and 2 (driver/passenger sides). Check this thread out: https://www.clublexus.com/forums/mai...fficiency.html
Edited: The GS300's have 3 o2 sensors...
Yep! Bank 1, sensor 2. Post cat on the drivers side. Was fairly obvious when I hooked up the diagnostic and had the voltage readings from the datastream.
Lavrishevo
20
08-24-12 10:36 PM
chi123
08-14-12 06:27 AM
accelerate, accelerating, acceleration, bad, burning, car, catalytic, converter, exhaust, funny, gs300, hard, lexus, oil, smell
