Well my GS is refusing to stop
Old 06-28-10 | 08:02 PM
D-Boi's Avatar
D-Boi
how do i bleed the master cylinder i dont see a bleeder valve on it?
Old 06-30-10 | 09:54 AM
D-Boi's Avatar
D-Boi
bueller?? bueller?? anyone lol? how do i bleed this darn master Gents
Old 08-20-10 | 03:56 PM
D-Boi's Avatar
D-Boi
ok well i have an update: i bled the brakes again 3 more times and i used clear hose to see exactly how much air was in the system and it was a very very small amount. i bleeded all 4 calipers in the correct order. before that i bled the master but i dont know if i did it the right way, i disconnected each of the brake lines one after the other and had someone hold on the brake pedal and clear liquid came thru, im not too sure i did this correct but the brakes are still terrible you have to almost get it to the ground to stop. My buddy said to unplug the battery maybe to reflash the abs system but still no luck. the system has no air on it, and it cant be a bad master becasuse it was working perfectly bvefore i removed the calipers to paint them. ughhh i wish id never taken them off and painted them while on the car.....
Old 08-20-10 | 05:11 PM
GS4_Fiend's Avatar
GS4_Fiend
I think you cant bleed the master cylinder on our car....
Old 08-21-10 | 12:46 AM
D-Boi's Avatar
D-Boi
i wonder what the problem is with this thing, when the car is on ill tap on the brakes like 7-15 times and the abs light and brake and vsc lights come on and it beeps like a steady beep.
Old 11-25-11 | 03:24 PM
iRyan's Avatar
iRyan
i had this same problem and I couldn't find the issue...I am now here waiting on a new Master cyclinder so you know im upset
Old 11-25-11 | 11:05 PM
D-Boi's Avatar
D-Boi
Hey bud, i actually fixed this issue a long time ago on my former GS. It turned out to be my caliper pins they were seized. After i put new pins and grease car had perfect brakes. I dont know if you have ever checked the pins but it would not be a bad idea.
Old 11-26-11 | 02:40 AM
shurian's Avatar
shurian
If u need I have Master Cilynder good condition pm me
Old 11-26-11 | 05:26 AM
iRyan's Avatar
iRyan
I'll check that..thnks
Old 01-08-12 | 06:39 PM
mkbasham's Avatar
mkbasham
thanks for the posts. went from mushy to firm after the fluid bleed.
DrBrown54
Suspension and Brakes
09-14-15 07:23 AM
MrGetRT
05-05-13 10:31 AM
818GS
12-17-12 11:48 PM
nytoy
10-27-07 09:25 PM
SuperCoupe400
06-08-07 10:05 AM
