Finally, its done.....
#49
hmm...if this is my car i probably just do the conversion and do a regular dvd with navi instead..
alpine vehicle hub pro
newer oem navi ecu
datasystem video bypass
nav tool video inteface
for these 4 items isn't all come out to the same as a double din navi deck such as alpine 900?
i think it will be easier to used too..
unless you actually use your cassette.
newer oem navi ecu
#52
would sound awful on youtube....feel free to come to memphis and i will let you hear it though ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
thanks man....i MIGHT be up in nashville monday to get the alternator installed. if i am, wanna meet up?
it does...although im already re-working it.its in the shop as we speak. i think im gonna remake the top of the amp racks to have Plexiglas and LEDS around the plexi and probably make it one piece (although i will have to put some small axial fans underneath the Plexiglas to move air across the amps), the installer said the top piece was 2 pieces due to it not being able to fit into the trunk as a whole....not sure bout the bottom piece,he said he though it was a whole section (i said nah its got a seem in it). i think when i redo this trunk i will make it suede or something along those lines....im already thinking of "glassing" the sides. ashtray is ALMOST finished, is been smoothed in on the sides and fronts and just needs to be painted now
um you couldnt do that, you need something to in-cooperate the audio to nav of the touch screen (the alpine hub does this) unless u meant to pull the nav screen and convert to non-nav. yes that would have been easier but i didnt know i could do this till halfway into the build so it was to late by then
thanks....should look even better when i finish "tweaking" it
thanks man
newer oem navi ecu
newer oem navi ecu
thanks man
#54
i wish there is a cleaner way to do it on my ls430 not liking my vais adaptor on the oem screen wish it is aftermarket double din
#56
Great job with the patience on the build. I havn't done an audio build in years. They take time and lots of $ to do right. So, with all the dynomat, and equipment do you think its like 200lbs heavier? But yeah, great job.
#57
thanks henry i appreciate it
btw hahaha @ 200lbs.....im thinking its weighing in more like 600+ extra. i wanna get it weighed but dunno where to take it to get it weighed in
#59
http://en.wikipedia.org/wiki/Memphis_Motorsports_Park
