My GS400 setup
Suspension: Tein HA adjustable coil-overs, Intrax adjustable front and rear anti-swaybars, TRD Japan upper front one piece strut bar, TRD Japan lower chassis bar, Custom made rear strut one piece strut bar, TRD Europe steering ECU.
Wheels: OZ opera three piece - front 18-8.5 rear 18-10
Tires: Bridgestone Pole position SO2's front 245/40-18 rear 295/35-18
Brakes: 11.9 slotted rotors, 4 Piston Calipers, Stainless Steel Brake Lines, Metallic Pads.
Engine: ATI Procharger(supercharger), High flow two core intercooler, blowoff valve, RC engineering 440cc injectors, In-tank holley 250-lph fuel pump, Custom made lighten and balance aluminum CNC crank pulley, SRT piggyback air/fuel computer, Perma-Cool oil cooler.
Exhaust: Greddy Power Extreme 115mm tip 70mm mandrel-bent piping.
Transmission: Modified Level Ten billet torque converter, Toyota Supra LSD with 3.27 gearing, Perma-Cool transmission cooler.
Body: RMM body kit - RMM Front Grill w/ Lexus Emblem, RMM Front Bumper, RMM Side Skirt Set, RMM Rear Bumper, RMM 3-piece Rear Spoiler
Accessories: RMM carbon-fiber engine cover, TRD racing oil cap, TRD racing radiator cap, autometer boost gauge, autometer air/fuel ratio gauge, Four point SaBelt racing harness.
Output Power:My est. power output is 425hp at the wheels - 500-525hp at the crank.
Currently I am running 10 pounds of boost max (10:5.1 compression - yikes!!!) with no problems. I want to go up to 15 pounds but my engine would need some actual work to make it happen or "boom".
The below picture was taken right before a show hence the graphics but now the car is stealth black with no decals whatsoever.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Incredible setup. Thanks for sharing. What about performance numbers? 0-60, 0-100?!, handling?
Do you race this beast?
What brand of brakes do you have? I'm getting tired of the mushy stock feeling. Did this improve with your changes?
Inquiring minds want to know!
