spacers for stock wheels
#31
In terms of aesthetics and given the wheels are the same width, the one with the lower offsets will "look better." Usually wheels with lower offsets will have a deeper lip (which looks cooler to most and granted it has an outer lip). This is why you see VIP'd cars with such low offsets and wide widths, sometimes offsets are even in the negative.
#32
Remember that is without fender mods. With fender mods, you can go even bigger (but I wouldn't recommend it). Just get wheels that fit your car correctly.
#33
OP glad u made this....
i have been wondering about this lately and didn't wanna post something about it as im sure its been covered and way to lazy to search all the tire threads to find out the info about what size spacers i would need on my oem 16's with 205/55/16 (i think this is my tire size i forgot and its late and im not going outside) and info for me lo_dit or can i use the same spacers as above??
looks good
looks good
and yes you could push it out to even 30mm up front and 38mm spacers in the rear if you felt the need to.
#34
No. My stock wheels are 17x8 with a +50 offset. When you add spacers, you move the wheel further outside. So you have to subtract 38mm from the rear wheel and 33mm from the front wheel. The wheels will be equivalent to a 17x8 with a +17mm in the front and a 17x8 with a +12mm offset in the rear.
'lo dit'.. as in booty hole? hahaha
#35
i also have OEM 16" wheels and OEM tire size was 225/55/16 for my gs430, could be different for gs300/400. but since you have 225/55/16, you can easily go with a 20mm spacer in front and a 25mm in rear. those were the spacers i used with the 16" oem setup.
#36
ok so i finally went and looked at my old rim.
oem 16" rim is 16 x 7 1/2 (i forgot to right down the offset like a dummy but from reading on here it looks like its +55 offset)
so is 20/25mm gonna def do it?
i found this one although he is on 19's it doesnt seem like its 100% in the back but thats ok, it looks better than oem
https://www.clublexus.com/forums/sus...led-w-pix.html
#38
Not!
#41
nope lol
#43
