Standard jack points
I place the jack about two feet from the very front of the frame in front of the car. Then put the jack stands right before where the frame bends up into the car. Then for the back i put the jack in the middle of the car then place the jack stands on the little round metal plate right in front of the wheel behind the side skirts. Its kinda hard to explain, BUT! Do not put the jack stand anywhere you'd like, SCARY things will happen!!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
If you look under the car you can clearly see the jack points.
If you want to lift both rears at the same time you can lift it from the diff.
You can also lift it from the tow hooks in the front or rear, but not recommended unless you have to as it causes flex in the body. But the actual jack points are located on both sides of the car close to the front and the rear. But seriously just look under the car, its not hard to spot them out.
This car is a pain in the but to to lift and stand. If you are looking to lift the car, it's on the side of the car running parallel (front to back), you will see two groves about 4 to 5 inches apart, put you jack between those two groove. Then put your stand on one of those metal parts...lol, choose wisely.
tjcbar (03-10-24)
Here you go. Hope this helps. Why are you anti-search anyway? jk enjoy.
https://www.clublexus.com/forums/gs-...he-car-up.html
for the rear the trunk/spare wheel well will do. dont be afraid to put force into the jack, may seem wobbly at first but it will go away.
good luck, and post pics.
