My abs and vsc and vsc off light is on
Old 07-12-10, 03:11 PM
Toyboy300
Toyboy300's Avatar
Originally Posted by ZeekGS300
i just bought the car yday and the lights are on.. how do i fix that or rest it?
I have the same problem after adjusting my coilovers last weekend. I must've damaged a sensor. Didn't get a chance to have it diagnosed yet. The car drives and brakes the same. I hope I'm not causing more damage to my GS.
Old 07-12-10, 08:30 PM
vwynn
vwynn's Avatar
FYI people in cali... by law peeps at autozone kragen n watever will not let you barrow the scanner :/ fml
Old 07-12-10, 11:34 PM
CoolGuy660
CoolGuy660's Avatar
Yep! what he said.
Old 07-13-10, 01:43 AM
ydjy
ydjy's Avatar
FYI 2nd GS owners: you don't need a scanner, just a paper clip and some know-how to get your codes.
Old 07-13-10, 09:33 AM
vwynn
vwynn's Avatar
have you tried that method with success?
Old 07-14-10, 03:26 AM
ydjy
ydjy's Avatar
yes I have. Used a copper wire, but a paper clip should be enough. All kinds of ECUs show their diagnostic information via warning lights, so be prepared to see a lot of blinking.
Old 07-14-10, 06:43 AM
VIS250P
VIS250P's Avatar
I beleive it is a speed sensor.. It happen on my buddy GS...
Old 07-20-10, 08:54 PM
vwynn
vwynn's Avatar
ok bringing this up...
i did the diagnostics... i see blinking lights and the ABS and VSC doing their own patter which means im supposed to read that.. however iono how to read it.. i read around the PDF n searched around but still clueless :/ help anyone??
Old 07-21-10, 12:19 AM
JDMCelsior
JDMCelsior's Avatar
so what I'm getting from this thread is that the VSC light can come on for just about any code. Mine has been on, along with the engine light for about 4 months now. My problem though is the cat (bank 1). I scanned mine at the dealership, so I'm pretty confident they got the code right. hmmm, interesting that this VSC light would come up for just about any code.
Old 07-21-10, 08:40 AM
vwynn
vwynn's Avatar
do they charge you to scan it at their place?
Old 07-21-10, 09:23 AM
wbmx1981
wbmx1981's Avatar
Mine was the oil control valve, about $100 bucks at the dealer.
Old 07-27-10, 10:53 PM
vwynn
vwynn's Avatar
sweetness! i fixed it it was my front passenger side ABS line ... no more dash lights ftw!... well i still have the tail light dash light on due to the LED... but other than that done!
Old 07-27-10, 11:03 PM
toy4life86
toy4life86's Avatar
so you cant get it checked from autozone in cali? I got a reader but i always read you could
Old 07-28-10, 12:25 AM
lowkeySC
lowkeySC's Avatar
^ nope you cant. i checked with my friend that works there.
Old 07-28-10, 06:42 AM
cloead
cloead's Avatar
all those lights were just on for me
i was replacing both front calipers and decided to clean the maf while i had the car apart
g/f was in the car helping me bleed the brakes and i didnt have the maf back in yet, she turned the key to on and it stored the code for bad maf ;/
cleared the code with my scan tool after putting everything back together and lights have stayed off
fyi - cleaning my maf did wonders for my car. drives much better now. no more hesitation from when i push the pedal down to the car actually moving
Quick Reply: My abs and vsc and vsc off light is on
