My abs and vsc and vsc off light is on
iModerate
Get the car hooked up to a diagnostic scan tool that can read the ABS/VSC system and see what the Diagnostic Trouble Codes are. These will point you toward the issue. Get the issue corrected and then reset the lights.
#1 Do a search
#2 Go to autozone and get the code checked
#3 Fix problem
There are TONS of threads that come up with this issue and ALMOST all of them end up being the front sensors. May not be your case but you should get the codes pulled, look them up and post.
As mentioned above Autozone will check it for free.
#3 Fix problem
iModerate
Standard OBDII readers only get basic Engine and Emissions codes and sometimes data. You need a "enhanced" scan tool that is capable of reading the ABS/VSC module.
