Holy Crap, my car wont shift out of park!
Old 07-10-10, 07:10 AM
EN_VY
EN_VY's Avatar
Unhappy Holy Crap, my car wont shift out of park!
Hello guys, I have another problem, If it isn't one thing, it's another.. Well, I was headed out last night and when I try to reverse out of the driveway, my shifter is stuck!.. I panicked because I was very late.. I toughts somehow the plastic inside had gotten stuck or something, so I took the whole center console out. Everything seemed fine, and I even took out the plastic.. I try hitting the little lever that lets you shift when your car os off, and it works! So I head out and do it 2 more times before I get back home.. Any suggestions as what messed up? ANother thing... Before, when I would hit the brakes, I would get a dash light indicating that my lights where burnt out, which they where.. Now, I get no dash light.. Maybe something isn't detecting me putting the brake? Please help!
Old 07-10-10, 08:27 AM
porn-adkt
porn-adkt's Avatar
Fuse
aight peace
Old 07-10-10, 10:55 AM
EN_VY
EN_VY's Avatar
Lol.. Ill look it up I guess. Thanks!
Old 07-10-10, 11:12 AM
excluesive
excluesive's Avatar
yeah pretty sure its a fuse
Old 07-10-10, 12:18 PM
marus
marus's Avatar
your stop fuse blew....... it happened to me before....... mine blew because i had a big car jack in my trunk and i drifted at this turn witch cause the jack in my trunk to pull wires of my tail lights and those wires touched the metal and blew my fuse. or it can be a sensor that may need to be replaced but first check the fuse in the fuse box near you foot brake ( it should be to the left of it.
Old 07-10-10, 10:55 PM
EN_VY
EN_VY's Avatar
Whoa, I replaced the "stop" fuse, and walla!!! The sucker now shifts! I can't understand how it blew out though Also, My rear lights fuse gave out too.. Oh, well. Im glad everything is ok now.. Thanks guys!
Old 07-10-10, 11:04 PM
Big Mack
Big Mack's Avatar
Exclamation
If both fuses blew, you have a problem that needs a bit more investigation. Don't assume that just because you've replaced the fuse you've fixed the problem. They don't usually just blow for no reason, especially two in the same circuit path. Check the wires near the lights for problems.
Big Mack
Old 07-11-10, 08:43 PM
Infamous 1
Infamous 1's Avatar
These issues are all related to your tail lights. Check your tail light wire harness and connections.
Old 07-11-10, 09:56 PM
EN_VY
EN_VY's Avatar
Yes! I kind of figured that my tail lights where causing all this mess, as I left my inners unplugged and with the harness hanging out.. Maybe they made contact with metal, as I have a lot of junk in the trunk.
Old 07-12-10, 11:33 AM
JiBBeL
JiBBeL's Avatar
How would an overweight *** cause this problem
sorry, had to do it
Old 07-12-10, 11:44 AM
Mr Jokster
Mr Jokster's Avatar
Just a guess... but you know how you have to press the brake pedal to release the safety on the shifter, thats where I would believe how the 2 are related.
Old 08-09-10, 12:37 PM
eyecon7
eyecon7's Avatar
my shifter is also stuck! which fuse do i check?
Old 08-28-10, 02:25 PM
eyecon7
eyecon7's Avatar
anyone????
Old 08-28-10, 04:36 PM
EN_VY
EN_VY's Avatar
On the drivers side fuse compartment, its going to be fuse number 14, its going to be a 15a fuse.. That might be confusing because if you count from fuse one it it wont add up, Im just saying what the manual tells you.. Do it like this: Go down to the 4th row and the 3rd fuse from the left, thats the one that needs to be replaced
Old 08-29-10, 10:54 AM
eyecon7
eyecon7's Avatar
I did that, fuse is good, this happend after i put my car in neutral and when i tried to put it in park it wouldnt budge! =/ its annoying to stick a screwdriver to shift out of park everyday
QCPete
RX - 1st Gen (1999-2003)
39
10-14-18 02:43 AM
ChuckMcCoy
07-04-15 08:46 AM
Rockero28
10-06-11 09:41 AM
gnats
SC- 1st Gen (1992-2000)
23
07-24-08 09:40 AM
mcnelson
Maintenance
01-09-03 06:43 PM
Quick Reply: Holy Crap, my car wont shift out of park!
