which pulley?
damn okay.. now I heard you can just put some compressor oil and sometimes it fixes it.?? I mean my ac blows ice cold and only time it makes a noise is when im at a stop and i give it gas..If im already driving and i turn on the ac, it doesnt make any noise.
What kind of noise is it making,a/c compressor normally makes noise wen u turn the a/c on.if its making noise like once. Every 3 second then ure probably low on freon.but if its a grinding type noise then u will need a compressor
there is nowhere to pour compressor oil. it must be added in with r134. unless you have a leak of some sort, adding something will not fix the issue. r134 and compressor oil are not consumable items like gasoline.
LexusFan2
ES - 5th Gen (2007-2012)
16
04-01-19 07:53 PM
