How to get rid of the "hyper flash" from installing LED turn signal?
#31
Yea... the Spyder inners are pretty nice. I had contemplated getting the full set of the Spyder outer and inner tail lights until I came across the Braga Type 3 led tails, it was love at first sight and not even the steep $500USD price tag was enough to stop me from getting them. I did have the OEM halogen turn signals in there for a little while after putting in the Braga, but having led turn signals in my other cars, it wasn't long before I couldn't resist switching over to the leds on the GS as well. Glad you liked the write-up hope it helps you out when it's your turn for led turn signals.
#32
I have that electronic flasher with the **** to control the speed of flashes per minute. I installed the electronic flasher a month before I installed the LED bulbs. Worked flawlessly with or without the LEDs. I got the JDM flasher from Amazon, the bulbs are also the JDM Astar Amber LEDs from Amazon, its been a good year with them.
#33
If you look at the link in my sig on LEDs, I used resistors wired on the rear tail light wire harness. Very easy.
#34
Could any body update me the limitation of LED relays? how could they know if one of bulbs burnt thus give waning? I think if it is only one bulb it should know. Yet not sure whether these relays works properly. Unless 100% they work well it seems a bad idea to just for a little bright bulbs.
I know many people like to decorate their cars, yet safety is the first issue.
#35
flash, grand, hyper, hyperflash, hyperflashing, installing, is350, led, load, prix, relay, resistors, signals, stop, turn
