would a crank pulley off of a 93sc work?
My crank pulley is messed up and makes noise when i turn on my ac. My mechanic has a 93 sc300 that he is parting out.. Its the same motor 2jzge but its non vvt-i
which idk will make a difference when it comes to the crank pulley..
will it work?
thanks
will it work?
thanks
what you can do is go to lexus web site to look at the park number and compare...i think u can go to sewell lexus website...if part number is teh same then yea... but another way is to compare side by side and also look at the timing mark to make sure its the same.... hope this help.... i think its the same but more research is nice...
If you using used check for cracks in the rubber ring if you can see major cracks then its junk and will seprate like yours all ready has
Dont forget crank pulley bolt tourqe is 320 nm
dwebb99
SC400 / 300 Classifieds
06-06-14 08:37 PM
6SOARER
Performance & Maintenance
04-21-14 01:04 PM
