New GS mod from APEXI - fuel ECU
Old 07-08-02, 09:30 AM
DrewGS4
DrewGS4's Avatar
Default New GS mod from APEXI - fuel ECU
For the never ending search for mods, I came across this one for the GS. Not sure if many people have this, but for $330 its a pretty inexpensive mod.
It's called APEXi Super AFC S-AFC
Here is the description:
The digital APEXi S-AFC is a piggy-back fuel computer, which attaches to most any car. It is used to modify the factory computer signal in order to make adjustments for air/fuel ratios via enhancements through fuel adjustments.
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
We have ECU install and hook up guides for 1993-1998 Supra Twin Turbo's, New Celica's, Lexus IS300 and GS400. The S-AFC is not car specific so it work's on most any vehicle made. Optimal tuning is achieved on a dyno
For more info you can go too:
http://www.apexi-usa.com/electronics_safc.asp
Old 07-08-02, 10:08 AM
GS400_PUSHER
GS400_PUSHER's Avatar
Nothing new about that!!! Its been mention here plenty of times before. There are a couple CL members here that has it or had it.
Old 07-08-02, 10:15 AM
SADDLE
SADDLE's Avatar
will that work on a GS3... is that the same thing that LexusRules has???
drew
Old 07-08-02, 10:20 AM
RacingAristo
Guest
Posts: n/a
S-AFC works on all models.
Sasha doesn't have S-AFC on his car, yet.
$330 is steep. The market price for this is $305 shipped. I've seen it drop to $295 shipped. If you don't mind an used unit, you can easily get it for around $200.
Like other said, it's not new. I think the 1st gen of S-AFC came before 2nd gen GS was introduced in U.S.
Old 07-08-02, 01:34 PM
CamRen
CamRen's Avatar
here is my Safc in the ashtray... Not tuned yet... but i did manage to get all the wires hooked up... pretty easy....
(and yes that radar detector wire is not there any more... i wired my radar threw the garage opener... so now more ugly wires!! )
Old 07-08-02, 02:38 PM
gs430ondubz
gs430ondubz's Avatar
Default i had it once
I use to have the AFC and AVC-R in my 99 Eclipse GSX. Here are some pics of it installed in my pass airbag. Might as well attach some pics of the whole car while I'm at it.
Old 07-08-02, 02:39 PM
gs430ondubz
Default 2
pic of the whole dash
Old 07-08-02, 02:40 PM
gs430ondubz
Default pic 3
pic of the side
gs430ondubz
Default pic 4
pic of the rear
Old 07-08-02, 02:42 PM
gs430ondubz
Default last one
3/4 view. sorry for all these non-lexus pics. just reminiscing.. geez, it was fun to drive that thing
Old 07-08-02, 03:15 PM
LexusRules
LexusRules's Avatar
nice eclipse man..
i have the RSM-GP, not S-AFC at this moment.
like your eclips iwill be getting AFC and AVC-R in the future...
Old 07-08-02, 05:19 PM
Received 2,438 Likes on 1,598 Posts
Default Re: i had it once
I have visions of that airbag going off and someone with the two Apexi units implanted in their forehead!
Old 07-08-02, 05:22 PM
gs430ondubz
Thumbs up hahaha
that would be funny for the passenger. of course i removed the airbag when i had it installed.
Old 07-09-02, 12:23 AM
enginyr
Banned
enginyr's Avatar
That' one smoking hot eclipse!
How's your persuit towards the $250k job coming along?
Old 07-09-02, 12:29 AM
gs430ondubz
Default thanx guys
thanx steve and lexusrules,
Steve: my quest is well under way. Hopefully, 2 years from today, I'll be on the Club Ferrari website. (If they have one).
LexusRules: Thanx man, but I don't own the Eclipse anymore. I sold that and decided to go with the GS. I thought I needed to grow up. But, dang it was hella fun to drive. thing was hitting high 12"s low 13's.
LexBrett
Maintenance
11-14-14 07:52 AM
scweetfl02
Performance & Maintenance
12-30-11 09:45 AM
modonna223
05-28-11 11:34 AM
Quick Reply: New GS mod from APEXI - fuel ECU
