Evaporator DIY w/ Pics
#46
I'm buying my AC kit in a few days, my AC went out on me. Great post by the way, I would never attempt this DIY, btw. But the repair manual says to replace the evaporator just pull the radio and slide the vent after removing a few bolts, was removing the whole dash necessary to replace the evaporator?
#49
Can you scan the page and post?
#50
About a year later and I am planning on doing this.
Should I change the
1. Dryer
2. Expansion valve?
http://shop.advanceautoparts.com/web...|GRP60000_____
3. Evaporator (does it matter which brand?)
http://shop.advanceautoparts.com/web...RPACPTAMS_____
Also I am experiencing wet carpets and now passenger side vents blowing warmer than the driver side vents.
Does anyone know the part number for the evaporator box seal/gasket? Or should I just seal the box permanently with a marine sealant?
Also not all evaporators come with insulation? Does anyone have a picture of what the insulation looks like?
If the OP is still out there can you help me out?
thanks
Should I change the
1. Dryer
2. Expansion valve?
thanks
#51
Chicotrini:
Here are a few pics of the original evaporator with the insulation. I am in the middle of the evaporator change right now. You can see where the old one was leaking in the lower right corner. I got my new evaporator from advance auto and it had the insulation already installed.
Personally I would change the expansion valve at the same time.
I doubt that you need a seal for the evaporator box, they screw together pretty tight. You might take a look at where the drain pipe attaches to the evaporator box, maybe the leak is there, or where the drain pipe goes through the firewall.
Good luck, this is not a job for the faint of heart.
Steve
98 GS300
03 GS430
04 GS430
Steve
98 GS300
03 GS430
04 GS430
#52
Yeh you definitely cannot change the evap with only pulling the radio... The dash has to come out... If someone can get it out without pulling the dash, they are a magician....
#53
Should I change the
1. Dryer
2. Expansion valve?
thanks
Should I change the
1. Dryer
2. Expansion valve?
thanks
#56
Rather than starting another thread, need some help... AC is down ... When I first turn the AC on it blows cool but not to the full potential for about 30sec. max, then hot. I changed the expansion valve, but I'm thinking its the evaporator... Before I start breaking the car down I wanted to get some feed back before hand ...
#57
Wicked, I posted on your other thread... I had one here, but I guess i didnt submit it... It doesnt sound like its your evap if it still gets cold upon start up...
#59
Turns out I have a leak from the evap and lexus quoted $2500. Thanks for the write up I feel better now to attempt this. How much did it cost you I'm looking at about $200 so far with the core expansion valve and dryer/cooler. Am I forgetting anything?
