idles really low 500>. is there a way to set the idle? i have to drive around with the A/C on to keep the idle smooth. any help would be appreciated.
thanks
ps...... already did a tune up and had all the basic areas checked. also i am not throwing any codes. everything runs great....... just a really low idle.
Replace your engine mounts and/or transmission mount. It won't cure the low idle (which isn't really a "problem") but will solve the symptom (vibration at idle)
iirc, it's the pcv valve that is causing this problem.
yes this could also be the culprit, i cleaned out my MAF and TB and still a low idle, then i replaced the PCV a few days ago and the idle went up to normal.
