Fuel filter change slight Problem HELP
after taking apart the old fuel filter there are two little plastic O rings that felt out of somewhere and im not sure where to put them back . i have changed the rubber O rings on the new filter but the plastic O rings don't know where they go
someone help me before i put everything back together
Ok dude, the fist and most important thing, DO NOT LOSE THIS PLASTIC PIECE!!!! Lexus does not sell it at all, whether you buy a new pump or a new filter, so if you lose it, you'll have to find a whole used assembly somewhere at a junk yard.
I'm gonna find my diagrams and update you.
I don't remember now, but I assume only one of them will fit.
I think the other one might go between the pump and the filter.
Just make sure you don't lose any parts from the old assembly. Your fuel system is pressurized at 55psi, so if you lose one of the o-rings or groomets, you're going to be in trouble.
