UAS-Air Ride question
So I found this UAS kit for my GS3 at my friends shop
& they gave me this info & I have no idea if its good or bad
Please Help me, I don't want to do something stupid
"This kit will lower down 5” and will ride best at 2-3” below stock height
FRONT AIR STRUT KIT
REAR AIR STRUT KIT
5 GALLON NON-CORROSIVE ALUMINUM HIGH-PRESSURE AIRTANK
COMPRESSOR PSI CUT-OFF SWITCH
3/4HP COMPRESSOR 100% DUTY CYCLE 180PSI MAX(SEALED COMPRESSOR)
4 WAY ELECTRIC AIR-VALVE SETUP 3/8" 300PSI(INDEPENDENT CORNER CONTROL)**NEW AIR ENGINE VALVES**BULLET PROOF**
3/8 HI-PRESSURE AIRHOSE & FITTING KIT
4 FAST RESPONSE SWITCH-PANEL
(2) LIGHTED PSI GAUGES
*ALL PARTS WILL BE MOUNTED ON A PLATFORM FOR EASY INSTALL AND CLEAN LOOK
*2-3 SECOND INFLATION/DEFLATION TIME
*4-CORNER CONTROL(FRONT-BACK, SIDE-SIDE, 4-CORNER INDIVIDUAL, AND PANCAKE)
SPEED CONTROL UP/DOWN INFLATION"
FRONT AIR STRUT KIT
REAR AIR STRUT KIT
Cost:$2380
Any help would be great
As for slammed. They probably dont know the secret mods to make that happen as well as may not do them due to their content. You need to shave the mount up front and you can get a good inch to two inches more of drop (but then again, the billet kit takes care of that) for the back there are 'cups' that are like 3 inches long that you can cut in half or eliminate completely and put a strong washer in there to drop all the way I havent heard of any kits from UAS like the billet for the rear.
circled part cut or remove the whole thing and replace with washer. This part holds the strut from going through the top hat.
