well, funny enough, the green/yellow wire under the passenger door sill on the passenger side DIDN'T work like the schematics said BUT i removed the glove box and found the green/yellow plug coming into the car that DOES work. i will finish up passenger side tonight and start drivers side.....sorry rain on sat and a possible groin pull from soccer this weekend have put me behind.
Just FYI it requires IE to open. It will not open in FF. At least not for me.
ahhhhhhhhhh no wonder abel. i no longer use IE except for work stuff where we have to use it, i hate it. i use FF for my personal playing at work
FF FTMFW
Originally Posted by GS4_Fiend
Lol.... My clock, footwell, and dome light is not working lol. Becareful when u are working with the footwell not to short it.
john....u need some test lights and a meter to be sure bout the wiring before you do this. as i said before....the green/yellow wire in the door loom ISNT the correct wire per alldata or the schematics ABLE gave me BUT the green/yellow wire coming into the car from the engine bay IS the correct wire, so the only 100% way to be sure is to check.
if you look at this post, you'll see i fried out my door control ecu (black box in upper left of the pic below) due to a faulty test light and me crossing a incorrect wire.....
luckily for me i have a really cool member in town and he let me use his to verify it and now he's fixing mine.
IF YOU GUYS WILL JUST GIVE ME A DAY OR SO I WILL FINISH THE DIY AND PEOPLE WILL HAVE A EASY HOOKUP...I will have this done no later than tues night but im hoping to have it done tonight.
Damn Brian, is it really necessary to cover the WHOLE door with dynamatt? You have that much bass in the fronts?
yes john it is
Originally Posted by ****-adkt
Very interested in your DIY Brian.
well its done. didnt come to work yesterday due to food poisoning but i have EVERYTHING hooked up im gonna turn all the photos/videos over to CLT as he said he wants to make a DIY (since he is a graphic designer, i think he said)
