Igniter for my 1998 GS400
hello members,
I`m looking for a Igniter for my 1998 GS400. Please see picture, part is circled in Red
![](http://i257.photobucket.com/albums/hh232/synco357/DSC03273.jpg)
If you have a igniter in good working order please contact me:
synco357@aol.com
561 716 2678
Thanks,
Andre
synco357@aol.com
561 716 2678
Thanks,
Andre
Because they didn't use a VIN or set the engine option. That part is only for the 300's. It tells you if a part is for one or for both so if someone told you that was it they didn't try hard enough. If you've already done plugs too, try moving around the good coils to other spots the see if the problem follows the coils.
What codes does it have?
If its all 8 then there are a few things i would check. First, I would hope it's just bad gas. Second, do plugs. Third, check the coils. If it's just one side of the engine (1,3,5,7) it could be VVT-i related. If it's all 8, you could also try swapping ECU's with a friend to check. If you swap ECU's to test you would also need their keys close to the ignition to get it to start.
O.K. I have check everything
Coil are good, installed in another gs and the worked fine
check my crank sensor and it read 2.2 ohms
check my cam sensor and it read 1.4 ohms
All new plugs
check my MAF meter and it read lower in ohms (specs) from what it says in the manual
If a MAF meter isn`t working would that cause the car not to have injector pluse and spark?
I have a 99 Gs400 ECU but I have to get one of my keys flashed to see what happens.
Any more suggestions?
All new plugs
