i think youll need to shave the rear, as for the front its pretty aggressive.. not too many people runnin 10s up front on stock fenders besides kam and i think hes pulled..
When you go with a bit more aggressive setup, these cars are meant to go with a staggered setup. If you go with the same size all-around, the front will stick out too much compared to the rear. I think that will look a bit weird.
I'm running 18x10 +20 (235/40/18) in the rear and need 10mm spacer to make it really HELLAFLUSH. Rolled fenders are a must and slammed is a must too which increases camber, that results in more space in the rear.
I could fit 18x10 +5 if I wanted to...which would be considered hellaflush.
