Car starts then Stalls
Old 09-02-10, 02:58 PM
masagsxr
masagsxr's Avatar
Default Car starts then Stalls
Trying to help cousin diagnose his 1998 Lexus GS400. Not exactly sure what the problem is. He says, he hit a pot hole pretty hard or something then the car stalled. Could not start the car back up. It would start then immediately stall/die. He had the car towed at his mom's house.
2nd problem: He wasn't sure if there was a CEL and we could not check it anymore since the battery ran out of juice and must have cleared the code.
Where should we start looking into to diagnose the problem?
I'll forward this post to him in hopes that he chimes in to explain to you guys exactly what happen the day he hit that pot hole.
Thanks!
Old 09-02-10, 06:02 PM
tinman
tinman's Avatar
Sounds like the battery cable or the alternator cable got knocked loose. When warm, the car starts up, then drops to ~500-750 RPM. The alternator can't power the entire car at that speed, and it will die. I had this problem on as SC and a GS. Oddly enough, even though my battery cable got knocked loose (just loose, not disconnected), i could still start the car.
Old 09-02-10, 06:20 PM
toy4life86
toy4life86's Avatar
yah sounds like a battery problem
Old 09-02-10, 08:23 PM
AristoPra
AristoPra's Avatar
Thanks for the reply fellas! Replaced the battery and battery terminals and its still doing the same thing. Forgot to check the alternator cable so I'll check it tomorrow after work since the GS is at the parentals.
Old 09-02-10, 09:49 PM
tom steele
tom steele's Avatar
is the maf sensor loose? if it comes unplugged that happens so maybe it came loose.
Old 09-03-10, 01:48 AM
toy4life86
toy4life86's Avatar
how bad was the hit?
check the obvious stuff too fuses especially the main ones
Old 09-03-10, 08:55 AM
AristoPra
AristoPra's Avatar
well, i didn't hit a pot hole, i ran over a piece of debris and it kinda messed up one of the brackets that hold up the gas tank. i will definitely look over the things mentioned above as i just haven't had much time to look it over since it happened. thanks again for errone's input!!!!!!
Old 09-03-10, 12:09 PM
masagsxr
masagsxr's Avatar
This is why I wanted you to respond right away to begin with to state exactly what happen... I forgot you ran over something hahaaaa.....
Old 09-04-10, 09:29 AM
AristoPra
AristoPra's Avatar
Well, I just looked things over and I have a freakin' big **** gash on the gas tank!!!!!!!!
Anyone know where I can get a used gas tank for cheap!? !? !? Hopefully local to Rowland Heights since that's where the GS sits collecting dust and bird poop!!!!!
Again, thanks to errone who gave their inputs! It's greatly appreciated! THANKS!!!!
jean1982
09-22-14 11:37 PM
ilovesc430
05-07-11 10:35 AM
northtide
SC- 1st Gen (1992-2000)
09-17-09 10:26 AM
chiseenlow
06-17-08 04:16 PM
Mr2088
05-29-07 12:46 PM
Quick Reply: Car starts then Stalls
