Strongest aftermarket lug nuts
Old 09-06-10, 07:16 PM
nar8ta
nar8ta's Avatar
Default Strongest aftermarket lug nuts
After doing a search I found a thread where jeff encouraged a guy to pick up a set of McGard but a friend of mine said he has heard of people having problems with them. He has installed the kics lug nuts and had problems with them as well which are $200.
After my coilover calamity with Stance, and taking the wheels off and on a million times, I notice my aftermarket lug nuts keep getting cross threaded. I am tired of changing studs so I'm looking for a set which are stronger. I think i will go crazy if I put up $200 dollars and still have this problem. And yes I hand tighten the lug nuts first before tightening them.
I appreciate the info:
Old 09-06-10, 07:39 PM
GS4_Fiend
GS4_Fiend's Avatar
What was wrong with the Kics?
Try WedsSport... They are from Japan.
Old 09-06-10, 07:55 PM
Chin
Former Sponsor
Chin's Avatar
Cross threading does not automatically mean your lug nuts aren't up to the task. Are you just daily driving? No drifting or racing? If you are just driving, I can't see how lug nuts (assuming they are the correct thread/pitch) and you have the complimentary studs would fail. I know you said you are hand tightening, but is anyone using impact tools on your wheels?
Old 09-06-10, 07:59 PM
CK6Speed
CK6Speed's Avatar
I've taken off my McGard lugs time and time again for years. Never had a problem with them. Honestly, I'm not sure how you can cross thread a lug nut ever. If you hand tighten like you say you do, and use a simple torque wrench to properly torque (Not over torque) I would say it is near impossible to cross thread a lug nut.
Old 09-06-10, 08:00 PM
porn-adkt
porn-adkt's Avatar
cross threading is usually a sign of over tightening.
Old 09-06-10, 08:21 PM
Likwid XTC
Likwid XTC's Avatar
I've been using my kics r40 for a few years now. No problem at all
Old 09-06-10, 08:29 PM
5t341th
5t341th's Avatar
i've been using muteki sr48s for both my cars. works great.
plus, u dont want stronger lugnuts. they are supposed to be weaker than the stud. or else u will have problems
Old 09-06-10, 08:57 PM
Alexus_300
Alexus_300's Avatar
I've found that the McGard Spline drive to work perfectly on all of my cars. I use it for the past five years on my GS300 and supra and no problems at all.
Old 09-06-10, 10:48 PM
nar8ta
nar8ta's Avatar
PM V (spyder78), he will tell you all about them
Does made in japan mean always good?
Thanks for the plug
Old 09-06-10, 10:54 PM
nar8ta
nar8ta's Avatar
Daily driver, no impact gun...
Trust me, it happens....
Good info, thank you...get off the **** LOL
I'm glad you had some good experience with them.
I'll definitely look into them, thanks
They look nuts, what are the pros and cons with the open ended compared to the closed ended. Will the weather seep in there and ruin them eventiually?
I'll look into them as well thanks
Old 09-06-10, 11:15 PM
GSRSRT
GSRSRT's Avatar
1 question those Lexus sell OEM studs ? or i can just buy from any auto shop?
Old 09-07-10, 12:14 AM
nar8ta
nar8ta's Avatar
Any auto parts store sells studs....i drive around with a few in my trunk just in case LOL.
Old 09-07-10, 12:30 AM
GSRSRT
GSRSRT's Avatar
lolz thats a good thought!
Old 09-07-10, 10:19 AM
Spyder78
Spyder78's Avatar
I've had the Open ended Kics R40 for about 1.5 years. What would happen is that they would start cross threading, almost at the point where they were tight. I couldnt understand it as the stud was clean no sign of damaged threads. I eventually bought a tap and die set and every time I would run the die over the studs to make sure that they were clean and they always were. I would also use the tap to check the nuts and for some reason sometimes the threads were cross threaded, eventually the threading itself would strip out of the lug nut. I have 4 cross thread lug nuts and 2 nuts with the threading fully stripped out of them. Bear in mind I always install my lug nuts myself, torque with a torque wrench to 76 lbs. The kics were the worst investment I ever made, I was using them with ARP studs as well. So studs were definitely not the problem as I ended up using Autozone lugs nuts at the moment and they've been working fine for me. When I contacted Kics, they stated that they had no knowledge of a similar problem to mine. I asked them if I could purchase replacement nuts. they told me that they dont sell them separately, they informed me that I would have to purchase another set. I'm sorry but I just spend $180 on your product, which is crap and you are telling me that I need to spend another $180 in order to replace 6 nuts? I thought that it was ridiculous and I decided to take the loss and chuck the kics.
Old 09-07-10, 10:20 AM
Spyder78
Spyder78's Avatar
I've also used extended Work lug nuts in blue for a day and I thought that they looked nice, however cant tell you the quality but they are soft since putting a wrench on them twice managed to chip the finish, I can only imagine what they look like after a year of removing and mounting the wheels.
Quick Reply: Strongest aftermarket lug nuts
